ViewSonic VA2465SM-3 23.6" 1920x1080 5ms VGA DVI with Speakers
Quicklinx: BP7RWS00 Mfr#: VA2465SM-3
The ViewSonic VA2465SM-3 is a widescreen monitor with an LED backlight and glossy, thin-bezel design great for use in the home or at the office. With Full HD resolution, high static contrast ratio and SuperClear VA technology, the VA2465SM-3 delivers stunning color and contrast with amazing screen performance at any viewing angle. Flicker Free technology and a Blue Light Filter help to eliminate eye strain from extended viewing periods. Paired with VGA and DVI inputs, the VA2465SM-3 allows flexible connection to PC systems, laptops and other multimedia devices. As a complete multimedia package, the monitor also includes a pair of integrated speakers.
  • Full HD for high pixel performance
    This monitor features Full HD resolution for unbelievable pixel-by-pixel image performance. You will experience an amazing clarity and detail whether it be while working, gaming or enjoying your favorite multimedia.
  • SuperClear VA image enhancement technology
    SuperClear image enhancement technology delivers advanced color performance and extends display viewing angles both horizontally and vertically. Experience accurate and vivid colors with consistent levels of brightness whether looking at the screen from above, below, the front, or the side with no color distortion or decay.
  • ViewSonic Flicker Free viewing for improved eye comfort
    ViewSonic flicker-free displays eliminates screen flickering at all brightness levels to provide a more comfortable viewing experience.
  • Blue Light Filter for more comfortable viewing
    ViewSonic displays feature a Blue Light Filter setting that allows users to adjust the amount of blue light emitted from the screen to increase eye comfort for work and multimedia applications.
  • Better color depth
    A high static contrast ratio of 3000:1 offers a wide range of deeper, richer colors with more visible details in shadows and highlights. This monitor can display vivid and realistic images for photo editing, watching movies, or any multimedia application.
  • Dual integrated stereo speakers
    This monitor is designed with two integrated 2W stereo speakers for enhanced multimedia performance with crystal-clear stereo sound.
  • Mercury Free LED backlighting
    LED backlighting not only enhances monitor performance but it’s also eco-friendly, mercury-free, and uses less energy than conventional monitors.
ViewSonic VA2465Sm-3 - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
250 cd/m²
Contrast Ratio
3000:1
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
67% NTSC, 73% Adobe RGB, 94.4% sRGB
Input Connectors
DVI, VGA
Display Position Adjustments
Tilt
Voltage
AC 100/240 V (50/60 Hz)
56.389 cm x 19.314 cm x 40.719 cm
4.1 kg
Europe
Environmental Standards
ENERGY STAR Qualified
CB, FCC, RoHS, WEEE, REACH, UkrSEPRO, ERP
(Austria, Germany, Switzerland - 2 years)
Display Type
Diagonal Size
24"
Viewable Size
23.6"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
3000:1
Colour Support
Colour Gamut
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
SuperClear, Eco-Mode, Flicker Free technology, Blue Light Filter technology
56.389 cm x 19.314 cm x 40.719 cm - with stand
4.1 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , DVI , Audio line-out , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x audio cable
Europe
Input Voltage
Power Consumption (Typical)
22 Watt
Dimensions & Weight Details
Without stand - width: 56.389 cm - depth: 4.596 cm - height: 34.709 cm - weight: 3.6 kg , With stand - width: 56.389 cm - depth: 19.314 cm - height: 40.719 cm - weight: 4.1 kg
Sustainability Information
ENERGY STAR Certified
Regional Warranty Exceptions
