The ViewSonic VA2465SM-3 is a widescreen monitor with an LED backlight and glossy, thin-bezel design great for use in the home or at the office. With Full HD resolution, high static contrast ratio and SuperClear VA technology, the VA2465SM-3 delivers stunning color and contrast with amazing screen performance at any viewing angle. Flicker Free technology and a Blue Light Filter help to eliminate eye strain from extended viewing periods. Paired with VGA and DVI inputs, the VA2465SM-3 allows flexible connection to PC systems, laptops and other multimedia devices. As a complete multimedia package, the monitor also includes a pair of integrated speakers.
Full HD for high pixel performance
This monitor features Full HD resolution for unbelievable pixel-by-pixel image performance. You will experience an amazing clarity and detail whether it be while working, gaming or enjoying your favorite multimedia. -
SuperClear VA image enhancement technology
SuperClear image enhancement technology delivers advanced color performance and extends display viewing angles both horizontally and vertically. Experience accurate and vivid colors with consistent levels of brightness whether looking at the screen from above, below, the front, or the side with no color distortion or decay. -
ViewSonic Flicker Free viewing for improved eye comfort
ViewSonic flicker-free displays eliminates screen flickering at all brightness levels to provide a more comfortable viewing experience. -
Blue Light Filter for more comfortable viewing
ViewSonic displays feature a Blue Light Filter setting that allows users to adjust the amount of blue light emitted from the screen to increase eye comfort for work and multimedia applications. -
Better color depth
A high static contrast ratio of 3000:1 offers a wide range of deeper, richer colors with more visible details in shadows and highlights. This monitor can display vivid and realistic images for photo editing, watching movies, or any multimedia application. -
Dual integrated stereo speakers
This monitor is designed with two integrated 2W stereo speakers for enhanced multimedia performance with crystal-clear stereo sound. -
Mercury Free LED backlighting
LED backlighting not only enhances monitor performance but it’s also eco-friendly, mercury-free, and uses less energy than conventional monitors.
- ViewSonic VA2465Sm-3 - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 67% NTSC, 73% Adobe RGB, 94.4% sRGB
- Input Connectors
- DVI, VGA
- Tilt
- Voltage
- AC 100/240 V (50/60 Hz)
- 56.389 cm x 19.314 cm x 40.719 cm
- 4.1 kg
- Localisation
- Europe
- Environmental Standards
- ENERGY STAR Qualified
- CB, FCC, RoHS, WEEE, REACH, UkrSEPRO, ERP
- (Austria, Germany, Switzerland - 2 years)
- Display Type
- Diagonal Size
- 24"
- Viewable Size
- 23.6"
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1
- Colour Support
- Colour Gamut
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- SuperClear, Eco-Mode, Flicker Free technology, Blue Light Filter technology
- 56.389 cm x 19.314 cm x 40.719 cm - with stand
- 4.1 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- VGA , DVI , Audio line-out , Audio line-in
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x audio cable
- Localisation
- Europe
- Input Voltage
- Power Consumption (Typical)
- 22 Watt
- Dimensions & Weight Details
- Without stand - width: 56.389 cm - depth: 4.596 cm - height: 34.709 cm - weight: 3.6 kg , With stand - width: 56.389 cm - depth: 19.314 cm - height: 40.719 cm - weight: 4.1 kg
Sustainability Information
- ENERGY STAR Certified
- Regional Warranty Exceptions
- Austria, Germany, Switzerland - 2 years
