ViewSonic VA2445-LED 24" 1920x1080 5ms VGA DVI-D LED Black Monitor
Quicklinx: 8VV1WS00 Mfr#: VA2445-LED
The ViewSonic VA2446-LED is a 24" (23.6 Vis) widescreen monitor with an LED backlight and glossy, thin-bezel design ideal for use in the home or at the office. With Full HD 1920 x 1080 resolution and a 10M:1 dynamic contrast ratio, the VA2446-LED delivers stunning brightness and contrast, while a quick 5ms response time ensures crisp pictures and smooth playback. VGA and DVI inputs provide flexible and convenient connectivity, while a VESA-mountable design offers additional mount flexibility. With an efficient LED backlight and energy-saving Eco mode, the VA2446-LED is an environmentally friendly display choice.
  • Full HD resolution for superior pixel performance
    You can experience stunning clarity and detail with high-definition office, graphic design, video production, gaming and multimedia applications on ViewSonic's VA2446-LED monitor. It features Full HD 1920 x 1080p resolution to ensure excellent pixel-by-pixel image performance, while its 10,000,000:1 mega dynamic contrast ratio guarantees accurate image reproduction with rich, vibrant visual effects.
  • Mega dynamic contrast ratio for sharp, crisp images
    A superior dynamic contrast ratio of 10,000,000:1 better defines the relationship between the darkest and brightest colors, ensuring all displayed images are rich and detailed. Combined with an extremely fast 5ms response time, every motion is naturally and accurately reproduced without any blurs.
  • ENERGY STAR certification
    The VA2446-LED is environmentally sound, complete with an energy-saving mercury-free LED backlight and Eco-mode. Its ENERGY STAR certification means you save up to 40% in energy costs when compared to regular 24" monitors.
  • Energy-saving eco-mode
    ViewSonic's proprietary Eco-mode function gives you the choice to optimize (85%) or conserve (65%) energy, thus reducing display brightness and conserving energy by up to 30%. Especially in low ambient light, eco-mode adjusts brightness and improves visibility while reducing eye fatigue and prolonging the display's lamp life.
  • VESA mount and Kensington security lock compliant
    Designed for use in various settings, the VA2446-LED's robust design makes it safe and secure wherever it is installed. That's because it comes with a Kensington security lock slot and is VESA wall mount compliant - making it the perfect monitor for all office and public settings.
ViewSonic VA2445-LED - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 10000000:1 (dynamic)
Response Time
5 ms
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
57.14 cm x 21.21 cm x 40.09 cm
4.1 kg
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, UL, C-Tick, BSMI, cUL, CB, ICES-003 Class B, CCC, PSB, RoHS, WEEE, REACH, UkrSEPRO, ERP
Display Type
Diagonal Size
24"
Viewable Size
23.6"
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Response Time
5 ms
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
24 - 82 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Backlight Technology
WLED
Eco-Mode, Mega Dynamic Contrast Ratio
57.14 cm x 21.21 cm x 40.09 cm - with stand
4.1 kg
DVI-D , VGA
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
1 x VGA cable
Backlight Life
30,000 hours
Power Supply
Internal
22 Watt
Included Software
ViewSonic Wizard
Dimensions & Weight Details
With stand - width: 57.14 cm - depth: 21.12 cm - height: 40.09 cm - weight: 4.1 kg , Without stand - width: 57.14 cm - depth: 5.04 cm - height: 35.09 cm - weight: 3.72 kg
ENERGY STAR Certified
10 - 90% (non-condensing)
8VV1 StarTech.com Articulating Monitor Arm In Stock £101.86
8VV1 StarTech.com Dual Monitor Stand In Stock £69.36
8VV1 StarTech.com Cubicle Monitor Hanger In Stock £45.29
8VV1 StarTech.com TV/Monitor Arm - Wallmount In Stock £50.91
8VV1 StarTech.com Monitor Arm - Heavy Duty In Stock £72.79
