The ViewSonic VA2265Sm-3 is a widescreen monitor with an LED backlight and glossy, thin-bezel design ideal for use in the home or at the office. With Full HD 1920x1080 resolution, 3000:1 static contrast ratio and SuperClear VA technology, the VA2265Sm-3 delivers stunning color and contrast with amazing screen performance at nearly any viewing angle. ViewSonic's exclusive ViewMode provides intuitive presets to deliver optimized screen performance in different applications. In addition, Flicker-Free technology and a Blue Light Filter help to eliminate eye strain from extended viewing periods. Paired with VGA and DVI inputs, the VA2265Sm-3 allows flexible connection to PC systems, laptops and other multimedia devices. As a complete multimedia package, the monitor also includes a pair of integrated speakers. A VESA-mountable design offers additional mount flexibility. In addition, ViewSonic offers one of the industry's best pixel performance policies to provide a great value for the stylish, high-performance VA2265SM-3 monitor.
- ViewSonic VA2265Sm-3 - LED monitor - Full HD (1080p) - 22"
- LED-backlit LCD monitor - 22"
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 71% NTSC, 74% Adobe RGB, 96% sRGB
- Input Connectors
- DVI, VGA
- Tilt
- Voltage
- AC 100/240 V (50/60 Hz)
- 51.069 cm x 19.314 cm x 38.761 cm
- 3.6 kg
- Localisation
- Europe
- Environmental Standards
- ENERGY STAR Qualified
- CB, FCC, RoHS, WEEE, REACH, UkrSEPRO, ERP
- (Austria, Germany, Switzerland - 2 years)
- Display Type
- Diagonal Size
- 22"
- Viewable Size
- 21.5"
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1
- Colour Support
- Colour Gamut
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- SuperClear, Eco-Mode, Flicker Free technology, Blue Light Filter technology
- 51.069 cm x 19.314 cm x 38.761 cm - with stand
- 3.6 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- VGA , DVI , Audio line-out , Audio line-in
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x audio cable
- Localisation
- Europe
- Input Voltage
- Power Consumption (Typical)
- 22 Watt
- Dimensions & Weight Details
- Without stand - width: 51.069 cm - depth: 4.716 cm - height: 31.938 cm - weight: 3 kg , With stand - width: 51.069 cm - depth: 19.314 cm - height: 38.761 cm - weight: 3.6 kg
Sustainability Information
- ENERGY STAR Certified
- Regional Warranty Exceptions
- Austria, Germany, Switzerland - 2 years
