ViewSonic VA2265SH 22" 1920x1080 5ms VGA HDMI LED Monitor
Quicklinx: BH0GWS00 Mfr#: VA2265SH
The ViewSonic VA2265Sh is a widescreen monitor with an LED backlight and glossy, thin-bezel design ideal for use in the home or at the office. With Full HD 1920 x 1080 resolution, 3000:1 static contrast ratio, and SuperClear VA technology, the VA2265Sh delivers stunning brightness and contrast with amazing screen performance at nearly any viewing angle. ViewSonic's exclusive ViewMode provides intuitive presets to deliver optimized screen performance in different applications. In addition, flicker-free technology and a Blue Light Filter help to eliminate eye strain from extended viewing periods. Paired with versatile input options including HDMI and VGA, the VA2265Sh allows flexible connection to PC systems, laptops and other multimedia devices. A VESA-mountable design offers additional mount flexibility.
  • SuperClear Image Enhancement technology with wide viewing angles
    SuperClear Image Enhancement technology delivers the best color performance and extends display viewing angles to 178 degrees both horizontally and vertically. Experience accurate and vivid colors with consistent levels of brightness whether looking at the screen from above, below, the front, or the side - with no color distortion or decay.
  • Full HD 1080p for superior pixel performance
    This monitor features Full HD 1920 x 1080 resolution for unbelievable pixel-by-pixel image performance. You'll experience the most amazing clarity and detail whether it be while working, gaming, or enjoying the latest in multimedia entertainment.
  • ViewMode settings for digital content
    With five intuitive scenario presets, ViewSonic's unique ViewMode feature offers best-in-class screen calibration for accurate color rendering and excellent performance. The presets enhance gamma curve, color temperature, contrast, and brightness to deliver an optimized viewing experience for different screen applications.
  • ViewSonic flicker-free viewing for improved eye comfort
    ViewSonic flicker-free displays deliver more comfortable viewing. Rather than using Pulse Width Modulation that continuously turns the LED backlight on and off, ViewSonic flicker-free displays use DC modulation backlights that maintain a steady stream of direct current power - nearly eliminating screen flickering at all brightness levels by providing a constant LED light source.
  • Blue light filter for more comfortable viewing
    ViewSonic displays feature a Blue Light Filter setting that allows users to adjust the amount of blue light emitted from the screen, enabling longer viewing times and increased eye comfort for work and multimedia applications. It offers 100 levels of blue light filtering to relax users' eyes and adapt to all your daily digital activities.
  • The power of HDMI
    HDMI is the highest, future-proof video standard, guaranteed for true digital picture clarity. The HDMI interface on this monitor allows you to connect to a variety of HD devices including gaming consoles, Blu-ray players, laptop PCs, digital cameras, and many others for the ultimate true high-definition experience.
  • Better color depth with 3000:1 static contrast ratio
    An ultra-high static contrast ratio of 3000:1 offers a wider range of grayscale to show deeper, richer colors with more visible details in shadows and highlights. With a ratio 3-times higher than standard panels, this monitor can display vivid and realistic images for photo editing, watching movies, or any multimedia application.
  • Mercury-free LED backlighting
    LED backlighting not only enhances monitor performance, delivers an outstanding color range, and adjusts contrast ratios for remarkably detailed images, but it's also eco-friendly, mercury-free, and uses less energy than conventional monitors.
  • Eco-mode conserves more energy and cuts costs
    ViewSonic's proprietary Eco-mode energy-saving feature is built into all ViewSonic LED monitors. Eco-mode adjusts brightness and improves visibility, while reducing eye fatigue and prolonging the monitor's lamp life. With Eco-mode, the lifespan of the LED backlighting is also greatly increased.
  • Dual international energy certification
    VA2265Sh complies with a current Energy Star 6.0 eligibility criterion which is an international standard for energy-efficient consumer products, originated by EPA (Environmental Protection Agency) in the United States. Meanwhile, this model meets the MEPS (Minimum Energy Performance Standards) with a 6-star, certified by Australia. VA2265Sh is definitely a monitor with great efficiency that meets stringent energy-efficient requirements globally.
  • VESA-mountable
    The ViewSonic VA2265Sh features a 100 x 100 mm VESA-mountable design that allows you to mount the display on a monitor stand or on a wall, depending on your specific needs. You can easily detach the base by unscrewing four screws and then mounting the display on its stand or wall mount.
ViewSonic VA2265Sh - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 50000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
71% NTSC, 74% Adobe RGB, 96% sRGB
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
51.069 cm x 19.314 cm x 38.761 cm
3.6 kg
Environmental Standards
ENERGY STAR Qualified
C-Tick, BSMI, CB, PSB, FCC, RoHS, WEEE, Green Mark, MEPS, REACH, ERP, NMB-3 Class B, CAN ICES-3 Class B
2-year warranty (Austria, Germany, Switzerland - 2 years)
Display Type
Diagonal Size
22"
Viewable Size
21.5"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
24 - 82 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
SuperClear, Eco-Mode, Flicker Free technology, Mercury free, Blue Light Filter technology
51.069 cm x 19.314 cm x 38.761 cm - with stand
3.6 kg
VGA , HDMI
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
1 x VGA cable
Backlight Life
40,000 hours
Input Voltage
Power Consumption (Typical)
22 Watt
Power Consumption Stand by
0.5 Watt
Dimensions & Weight Details
Without stand - width: 51.069 cm - depth: 4.716 cm - height: 31.938 cm - weight: 3 kg , With stand - width: 51.069 cm - depth: 19.314 cm - height: 38.761 cm - weight: 3.6 kg
Sustainability Information
ENERGY STAR Certified
Regional Warranty Exceptions
10 - 90% (non-condensing)
