ViewSonic VA2055SA 19.5" Full HD VGA Monitor
Quicklinx: BHYCWS00 Mfr#: VA2055SA
The ViewSonic VA2055Sa features a 20" Full HD SuperClear MVA widescreen panel. The monitor offers 1920 x 1080 resolution, 3,000:1 contrast ratio, VGA inputs, and a VESA-compatible mount design. In addition, Flicker-Free and blue light filter technology help to eliminate eye strain from extended viewing periods. ViewSonic's exclusive ViewMode provides intuitive presets to deliver optimized screen performance in different applications. Lastly, with one of the industry's best pixel performance policies, ENERGY STAR and EPEAT Silver certification, and an energy-saving Eco-mode, the VA2055Sa is a great long-term investment for any of your entertainment or professional needs.
  • SuperClear: stunning color performance & wide-angle viewing
    Enjoy accurate and vivid colors with consistent levels of brightness no matter the vantage point. With SuperClear MVA panel technology, this monitor delivers the same image quality whether you are looking at the screen from above, below, the front, or the side.
  • Full HD 1080p resolution
    This monitor features Full HD 1920 x 1080 resolution for unbelievable pixel-by-pixel image performance. You'll experience the most amazing clarity and detail whether it be while working, gaming, or enjoying the latest in multimedia entertainment.
  • ViewMode: superior color rendering & intuitive settings
    ViewSonic's unique ViewMode feature offers "game" "movie" "web" "text" and "mono" presets. These presets enhance gamma curve, color temperature, contrast, and brightness to deliver an optimized viewing experience for different screen applications.
  • Enhanced viewing comfort
    Flicker-free technology and a blue light filter help to eliminate eye strain from extended viewing periods.
  • Lower energy consumption
    With an energy-saving Eco-mode feature, as well as ENERGY STAR and EPEAT Silver certification, this monitor delivers great power savings along with its stunning screen performance.
ViewSonic VA2055Sa - LED monitor - Full HD (1080p) - 20"
LED-backlit LCD monitor - 20"
Panel Type
MVA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
250 cd/m²
Contrast Ratio
3000:1
Response Time
25 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
47.22 cm x 21.17 cm x 34.91 cm
3.1 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, ICES-003, cULus, cTUVus, NRTL, cETLus
3-year warranty
Display Type
Diagonal Size
20"
Viewable Size
19.5"
Panel Type
MVA
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
3000:1
Colour Support
Response Time
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
24 - 82 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
Controls & Adjustments
Brightness, contrast, input select
SuperClear, Eco-Mode, Flicker Free technology, Blue Light Filter technology
47.22 cm x 21.17 cm x 34.91 cm - with stand
3.1 kg
VGA
Mechanical
Tilt
Tilt Angle
-3/+20
VESA Mounting Interface
100 x 100 mm
1 x VGA cable
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
Power Supply
External
Input Voltage
Power Consumption (Typical)
24 Watt
Dimensions & Weight Details
With stand - width: 47.22 cm - depth: 21.17 cm - height: 34.91 cm - weight: 3.1 kg , Without stand - width: 47.22 cm - depth: 4.75 cm - height: 28.78 cm - weight: 2.5 kg
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
7.0
Limited warranty - parts and labour - 3 years , Limited warranty - backlight - 3 years
20 - 90% (non-condensing)
