The ViewSonic VA2055Sa features a 20" Full HD SuperClear MVA widescreen panel. The monitor offers 1920 x 1080 resolution, 3,000:1 contrast ratio, VGA inputs, and a VESA-compatible mount design. In addition, Flicker-Free and blue light filter technology help to eliminate eye strain from extended viewing periods. ViewSonic's exclusive ViewMode provides intuitive presets to deliver optimized screen performance in different applications. Lastly, with one of the industry's best pixel performance policies, ENERGY STAR and EPEAT Silver certification, and an energy-saving Eco-mode, the VA2055Sa is a great long-term investment for any of your entertainment or professional needs.
SuperClear: stunning color performance & wide-angle viewing
Enjoy accurate and vivid colors with consistent levels of brightness no matter the vantage point. With SuperClear MVA panel technology, this monitor delivers the same image quality whether you are looking at the screen from above, below, the front, or the side. -
Full HD 1080p resolution
This monitor features Full HD 1920 x 1080 resolution for unbelievable pixel-by-pixel image performance. You'll experience the most amazing clarity and detail whether it be while working, gaming, or enjoying the latest in multimedia entertainment. -
ViewMode: superior color rendering & intuitive settings
ViewSonic's unique ViewMode feature offers "game" "movie" "web" "text" and "mono" presets. These presets enhance gamma curve, color temperature, contrast, and brightness to deliver an optimized viewing experience for different screen applications. -
Enhanced viewing comfort
Flicker-free technology and a blue light filter help to eliminate eye strain from extended viewing periods. -
Lower energy consumption
With an energy-saving Eco-mode feature, as well as ENERGY STAR and EPEAT Silver certification, this monitor delivers great power savings along with its stunning screen performance.
- ViewSonic VA2055Sa - LED monitor - Full HD (1080p) - 20"
- LED-backlit LCD monitor - 20"
- Panel Type
- MVA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1
- Response Time
- 25 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- VGA
- Tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- 47.22 cm x 21.17 cm x 34.91 cm
- 3.1 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- FCC Class B certified, ICES-003, cULus, cTUVus, NRTL, cETLus
- 3-year warranty
- Display Type
- Diagonal Size
- 20"
- Viewable Size
- 19.5"
- Panel Type
- MVA
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1
- Colour Support
- Response Time
- Vertical Refresh Rate
- 50 - 75 Hz
- Horizontal Refresh Rate
- 24 - 82 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- WLED
- Controls & Adjustments
- Brightness, contrast, input select
- SuperClear, Eco-Mode, Flicker Free technology, Blue Light Filter technology
- 47.22 cm x 21.17 cm x 34.91 cm - with stand
- 3.1 kg
- VGA
Mechanical
- Tilt
- Tilt Angle
- -3/+20
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable
- Backlight Life
- 30,000 hours
- Security Slot Type
- Kensington security slot
- Power Supply
- External
- Input Voltage
- Power Consumption (Typical)
- 24 Watt
- Dimensions & Weight Details
- With stand - width: 47.22 cm - depth: 21.17 cm - height: 34.91 cm - weight: 3.1 kg , Without stand - width: 47.22 cm - depth: 4.75 cm - height: 28.78 cm - weight: 2.5 kg
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 7.0
- Limited warranty - parts and labour - 3 years , Limited warranty - backlight - 3 years
- 0 °C
- 40 °C
- 20 - 90% (non-condensing)
