ViewSonic VA1903A 19" 1366x768 5ms VGA Monitor
Quicklinx: CQB7WS00 Mfr#: VA1903A
The ViewSonic VA1903a is a 19"(18.5" viewable) LED monitor which is the ideal choice for corporate, educational or home office use. In addition to a 16:9 widescreen and energy saving Eco mode, it is also equipped with ViewSonic's exclusive ViewMode, providing intuitive presets that deliver optimized screen performance in different applications. Besides, Flicker-Free technology and a Blue Light Filter help to eliminate eye strain from extended viewing periods for improved productivity. Lastly a VESA-compatible mount adapt easily to multi-monitor or wall-mount set ups.
  • 16:9 widescreen optimized for HD content
    Equipped with a 16:9 aspect ratio and 1366 x 768 native resolution, this monitor is designed for multitasking and improving productivity in the workplace or at home.
  • ViewMode - superior color rendering & intuitive settings
    ViewSonic's unique ViewMode feature offers "Game," "Movie," "Web," "Text," and "Mono" presets. These presets enhance gamma curve, color temperature, contrast, and brightness to deliver an optimized viewing experience for different screen applications.
  • ViewSonic flicker-free viewing for improved eye comfort
    ViewSonic flicker-free displays deliver on the promise of more comfortable viewing. ViewSonic flicker-free technology nearly eliminates screen flickering at all brightness levels by providing a constant LED light source. This lets you work at your computer, play games, or watch movies longer - without eye fatigue. Care for your eyes with ViewSonic flicker-free technology!
  • Blue light filter for more comfortable viewing
    Prolonged exposure to certain levels of blue light can cause eye discomfort. ViewSonic displays feature a Blue Light Filter setting that allows users to adjust the amount of blue light emitted from the screen, enabling longer viewing times and increased eye comfort for work and multimedia applications. It offers 100 levels of blue light filtering to relax users' eyes and adapt to all your daily digital activities.
  • Eco-mode conserves more energy and cuts costs
    ViewSonic's proprietary Eco-mode energy-saving feature is built into all ViewSonic LED monitors. Eco-mode adjusts brightness and improves visibility, while reducing eye fatigue and prolonging the monitor's lamp life. With Eco-mode, the lifespan of the LED backlighting is also greatly increased.
  • VESA-compatible mount design
    Mount the monitor as you see fit using its convenient 75 x 75 mm VESA-mountable design.
ViewSonic VA1903a - LED monitor - 19"
LED-backlit LCD monitor - 19"
Native Resolution
1366 x 768
Brightness
200 cd/m²
Contrast Ratio
600:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
43.8 cm x 17 cm x 34.4 cm
2 kg
Europe
DOC, REACH, ERP, SVHC, CU
(Austria, Germany, Switzerland - 2 years)
Display Type
Diagonal Size
19"
Viewable Size
18.5"
Native Resolution
1366 x 768
Brightness
200 cd/m²
Contrast Ratio
600:1
Colour Support
Response Time
5 ms
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
24 - 82 kHz
Horizontal Viewing Angle
90
Vertical Viewing Angle
65
Screen Coating
Backlight Technology
WLED
A-Si technology
43.8 cm x 17 cm x 34.4 cm - with stand
2 kg
VGA
Mechanical
Tilt
Tilt Angle
-3/+18
VESA Mounting Interface
75 x 75 mm
1 x VGA cable
Backlight Life
30,000 hours
Europe
15 Watt
Dimensions & Weight Details
With stand - width: 43.8 cm - depth: 17 cm - height: 34.4 cm - weight: 2 kg , Without stand - width: 43.8 cm - depth: 4.8 cm - height: 27.1 cm - weight: 1.8 kg
10 - 90% (non-condensing)
