The ViewSonic PJ-WPD-200 USB wireless adapter provides added convenience and flexibility to your projection needs. With the PJ-WPD-200, you can wirelessly project and you can use your Android or iOS devices to wirelessly stream content to a projector. Equipped with 2T2R MIMO, and support for up to 300Mbps, the PJ-WPD-200 delivers high-speed and robust data transmission via the IEEE 802.11b/g/n protocol. In addition, the portable and compact design of the PJ-WPD-200 provides an easy way for users to wirelessly connect their projectors. The PJ-WPD-200 is compatible with USB 2.0, most laptops, and select ViewSonic projectors equipped with ViewSync Advanced Connect Technology (ACT), as well as select ViewSonic PLED models.
Portable and compact design
With its portable and compact design, the PJ-WPD-200 provides an easy way for users to wirelessly enable their projectors. -
Wireless flexibility with mobile app
This wireless adapter lets users wirelessly project from different laptops, as well as from Android or iOS devices, with the ViewSonic vPresenter mobile app. -
A more reliable wireless connection
Equipped with 2T2R MIMO technology, this wireless adapter provides a solid wireless connection and reliable communication performance even in a complex Wi-Fi environment.
- ViewSonic PJ-WPD-200 - network adapter - USB 2.0
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- USB 2.0
- 1.6 cm x 2.9 cm x 0.7 cm
- 3.7 g
- Data Link Protocol
- 802.11b/g/n
- Frequency Band
- 2.4 GHz
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- System Requirements
- Apple MacOS, Microsoft Windows XP / 7 / 8
- Designed For
- ViewSonic PG603W, PG603X
- Network adapter
- Form Factor
- External
- USB 2.0
- Connectivity Technology
- Wireless
- Spread Spectrum Method
- OFDM, DSSS
- Frequency Band
- 2.4 GHz
- Max Range Open Space
- 277 m
- Ad-Hoc Mode, 2T2R MIMO technology, ViewSync Advanced Connect Technology (ACT)
- Encryption Algorithm
- AES, 128-bit WEP, 64-bit WEP, TKIP, WPA, WPA2
- OS Required
- 1.6 cm
- 2.9 cm
- 0.7 cm
- 3.7 g
- Designed For
