Your basket is empty
ViewSonic Ultra Portable PLED-W800 WXGA LED 800 Lumens Projector
Quicklinx: 9YYLWS00 Mfr#: PLED-W800
Brightness: 800ANSI lumens
Portability: Portable
£461.46 ex VAT
£553.75 inc VAT
The ViewSonic PLED-W800 is an ultra-portable LED projector with 800 ANSI lumens and WXGA 1280 x 800 native resolution. With a compact lightweight design, a USB reader/5V charging port, and extremely long hours of lamp life, this projector is ideal for both home entertainment and office use. The exclusive SuperColor offers a wide color range for the true-to-life image projection. An MHL-enabled HDMI input allows users to present directly from compatible mobile devices, as well as from wireless HDMI dongles. It also features an SD card slot, USB reader port. A built-in ViewSonic SonicMode sound system and dual integrated 2W speaker provide clear sound quality for multimedia content. With the ability to deliver incredibly sharp and vibrant images of up to 100", this projector is perfect for 720p HD widescreen viewing. In addition, auto vertical keystone correction helps users start to present instantly. The PLED-W800 projector delivers the superior performance and value for business travelers, education, and home entertainment.
ViewSonic PLED-W800 - DLP projector - portable
DLP projector - High Definition 720p
Built-in Devices
Stereo speakers
Microdisplay
DMD Chip
Brightness
800 lumens
Contrast Ratio
120000:1 (dynamic)
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb type
LED 50 Watt
Bulb life cycle
Up to 30000 hour(s)
Video Input
Composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, PAL 60, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM D/K, SECAM B/G, M-NTSC)
Supported Memory Cards
SD Memory Card
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
90 Watt
17.5 cm x 13.8 cm x 5.15 cm
830 g
3 years warranty
DLP projector - HD 720p
Built-in Devices
Stereo speakers
Projector
Microdisplay
DMD Chip
Brightness
800 lumens
Contrast Ratio
120000:1 (dynamic)
Image Size
60 cm - 254 cm
Projection Distance
0.7 m - 3.02 m
Throw Ratio
1.4:1
Resolution
WXGA - WXGA (1280 x 800) (native) / 1680 x 1050 (resized)
Native Aspect Ratio
16:10
Colour Support
Max Sync Rate (V x H)
85 Hz x 100 kHz
Bulb type
LED 50 Watt
Bulb life cycle
Up to 30000 hour(s)
Controls & Adjustments
Keystone correction
Built-in 2 GB flash memory, 16:10 aspect ratio support, Super Color, ViewSonic SonicMode
Lens
Focus Type
Manual
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
Analogue video Signal
Composite video
Video Interfaces
VGA, HDMI, composite video
Video Modes
SD Memory Card
Speakers
Integrated
Sound Output Mode
Stereo
Output Power / Channel
1 Watt
Speakers
2 x right / left channel
Expansion Slots
1 x SD Memory Card
1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x USB - 4 pin USB Type A , 1 x audio line-in - mini-phone 3.5 mm , 1 x composite video/audio input - mini-phone 3.5 mm , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x audio line-out - mini-phone 3.5 mm
Carrying case, wireless remote control
1 x HDMI cable
Security Features
FCC Class B certified, UL, cUL, ICES-003, NOM, CB, RoHS, REACH, KC, EAC
Power Source
AC
Nominal Voltage
90 Watt
Power Consumption Stand by
0.5 Watt
Software Included
ViewSonic Wizard
17.5 cm
13.8 cm
5.15 cm
830 g
Limited warranty - parts and labour - 3 years , Limited warranty - lamp - 1 year , Limited warranty - express exchange - 1 year
10 - 90% (non-condensing)
Brand: ViewSonic
Price Range Ex VAT: 300 - 500
