The ViewSonic TD2420 is the perfect solution for both commercial and consumer touch screen applications. With an intuitive multi-touch LED display, interactive stylus, and full HD resolution, the TD2420 delivers a versatile touch solution for use as a POS display, information kiosk, or in hospital and classroom environments. With Dual Point Optical technology, the TD2420 provides a fun and interactive experience to engage users. Equipped with 1920 x 1080 Full HD resolution, and 20,000,000:1 MEGA Dynamic Contrast Ratio, the ViewSonic TD2420 delivers extremely sharp and crisp images. As a complete multimedia package, the display also includes a pair of integrated 2-watt speakers with SRS Premium Sound. HDMI, VGA, and DVI inputs provide flexible and convenient connectivity, while a VESA-mountable design offers additional convenience for use as a wall-mounted display. The versatile TD2420 is the one-stop solution for your multi-touch display needs.
Dual point optical touch
Dual point optical touch utilizes two or more image sensors that are usually placed around the edges of a display. These sensors allow the touch surface to recognize two contact points simultaneously, and provide users with direct interaction by allowing two-finger gestures such as zoom in/out, rotations, and two-finger taps. Because of optical touch's scalability, versatility, and affordability, it is becoming a popular technology for use on large format displays. -
LED monitor
The term "LED monitor" generally refers to a monitor with a LCD panel and a LED backlight. A typical LCD monitor uses cold cathode fluorescent lamps (CCFL) as a light source to illuminate the LCD panel. In an LED backlit monitor, white LEDs (Light Emitting Diodes) are used as the light source. -
One-stop solution for multi-touch monitor needs
TD2420's multi-touch interface and Full HD resolution makes it an ideal touch solution for both commercial and consumer applications. It gives commercial users the capability to create a direct and interactive user experience for their customers. Full HD resolution and high Dynamic Contrast Ratio delivers ultra image quality and color accuracy. Scratch-resistant surface hardness ensures the TD2420 can withstand heavy usage in a high traffic environment while maintaining a high quality touch experience. -
Eco-mode for up to 40% energy savings
ViewSonic's proprietary eco-mode function comes standard with the TD2420. When you don't need all of the powerful features that the TD2420 has to offer, you have the option to reduce the monitor's brightness, save energy, save the planet and prolong the lamp life. Especially under low ambient light conditions, adjusting the brightness will improve visibility by reducing eye fatigue. Reducing brightness will also prolong the monitor's lamp life, improving your return on investment. -
Full HD 1080p resolution
The TD2420 features a 24" widescreen with 1920 x 1080 resolution that is capable of displaying a native Full HD 1080p image. Devices that can display Full HD content output are getting more and more common. However, without a native Full HD display, you will not be able to experience the picture clarity and the details of the 1080p content you view. -
Save cash and save the planet
With its mercury-free backlight and low energy consumption, the ENERGY STAR certified TD2420 is not only environmentally friendly, but it's also friendly on your electricity bill. The savings of LED can add up to thousands of dollars saved for large install bases, such as big corporate buildings or schools.
- ViewSonic TD2420 - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24" - touchscreen
- Energy Class
- Class B
- Energy Consumption per Year
- 33 kWh
- Power Consumption (On mode)
- 23 W
- Touch-screen
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Brightness
- 210 cd/m²
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 5 ms
- Input Connectors
- HDMI, DVI-D, VGA
- Speakers
- Integrated
- Tilt
- Screen Coating
- 7H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 55.59 cm x 17.48 cm x 42.19 cm
- 3 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- FCC Class B certified, UL, C-Tick, BSMI, cUL, ICES-003, SASO, CB, CCC, PSB, RoHS, WEEE, GOST-R, E-Standby, UkrSEPRO, KC, ERP
- 3-year warranty (Austria, Germany, Switzerland - 3 years)
- Display Type
- Energy Class
- Class B
- 33 kWh
- Diagonal Size
- 24"
- Viewable Size
- 23.6"
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 210 cd/m²
- Contrast Ratio
- Response Time
- 5 ms
- Vertical Refresh Rate
- 50 - 75 Hz
- Horizontal Refresh Rate
- 24 - 82 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Screen Coating
- 7H Hard Coating
- Backlight Technology
- WLED
- Controls & Adjustments
- Brightness, contrast, colour balance, input select
- OptiSync, HDCP, Eco-Mode, SRS Premium Sound, Mega Dynamic Contrast Ratio
- Black
- 55.59 cm x 17.48 cm x 42.19 cm - with stand
- 3 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 2 Watt
Input
- Touch-screen - touchscreen
- Movement Detection Technology
- Optical
- VGA , DVI-D (HDCP) , HDMI , Headphones , Audio line-in
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- Stand, stylus
- Cables Included
- 1 x VGA cable , 1 x DVI cable , 1 x audio cable , 1 x USB cable
- Backlight Life
- 30,000 hours
- Supported Windows 7 Features
- Windows Touch
- Security Slot Type
- Kensington security slot
- Power Supply
- Internal
- Input Voltage
- 23 W
- Power Consumption (Typical)
- 25 Watt
- Included Software
- ViewSonic Wizard
- OS Required
- Microsoft Windows 7, Windows 8
- Dimensions & Weight Details
- With stand - width: 55.59 cm - depth: 17.48 cm - height: 42.19 cm - weight: 3 kg , Without stand - width: 55.59 cm - depth: 5.61 cm - height: 34.68 cm - weight: 2.4 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - parts and labour - 3 years
- Regional Warranty Exceptions
- Austria, Germany, Switzerland - 3 years
- 0 °C
- 40 °C
- 20 - 90% (non-condensing)
