ViewSonic TD2220-2 22" 1920x1080 5ms Analogue DVI USB LED Monitor
Quicklinx: 92KBWS00 Mfr#: TD2220-2
Diagonal Size: 22in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: None
Interfaces: DVI, VGA (HD-15)
More than 50 in stock
£174.86 ex VAT
£209.83 inc VAT
The 22" ViewSonic TD2220 is a multi-touch Full HD LED backlit monitor with 1920 x 1080 resolution, DVI & VGA inputs and VESA mountable design. It has 20,000,000:1 MEGA dynamic contrast ratio for sharp crisp images and Eco-mode for up to 40% energy savings come standard in the 22" offering. The TD2220 is a one-stop solution for your multi-touch monitor needs.
  • Multi-touch screen with 8H surface hardness
    Simply touch, drag, resizes and manipulates, photos, documents or web pages, just like on your favorite mobile devices! 8H scratch resistant surface hardness ensures a consistent high quality touch experience and durability.
  • Full HD 1080p display with 1920 x 1080 resolution
    The 22" Full HD monitor supports imaging intensive commercial applications, video and image editing and entertainment. 20,000,000:1 MEGA dynamic contrast ratio provides a crisp image with high level details.
  • OptiSync digital/analog inputs expand your connectivity
    The TD2220 can be connected through USB for instant two-point touch operation and for experiencing easy navigation through intuitive touch operation. Two USB ports for additional connectivity for peripherals and electronic devices. Multi-mode input technology supports both digital (DVI) and analog (VGA) signals for compatibility and configuration flexibility.
  • ENERGY STAR and EPEAT Silver certified
    The TD2220 is TCO Compliant and environmentally sound with Energy-saving LED backlight and Eco-mode. You can save up to 40% in your energy cost comparing to a regular 22" monitor.
ViewSonic TD2220-2 - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22" - touchscreen
Touch-screen, USB Hub
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
200 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Screen Coating
8H Hard Coating
51.1 cm x 24 cm x 63.5 cm
4.92 kg
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, UL, C-Tick, BSMI, cUL, ICES-003, SASO, CB, CCC, PSB, RoHS, WEEE, GOST-R, E-Standby, UkrSEPRO, TCO Displays 5.2, KC, ERP
(Austria, Germany, Switzerland - 3 years)
Display Type
Diagonal Size
22"
Viewable Size
21.5"
Built-in Devices
USB Hub
Native Resolution
Brightness
200 cd/m²
Contrast Ratio
Response Time
5 ms
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
24 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
8H Hard Coating
Backlight Technology
WLED
Controls & Adjustments
Brightness, contrast, H/V position, sharpness, colour balance, input select, colour temperature, H-size, aspect control
OptiSync, sRGB colour management, Eco-Mode, Mega Dynamic Contrast Ratio, HID Compliant
51.1 cm x 24 cm x 63.5 cm - with stand
4.92 kg
Input
Touch-screen - touchscreen
Movement Detection Technology
Optical
DVI-D (HDCP) , VGA , USB upstream (Type B) , 2 x USB downstream (Type A)
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
Backlight Life
40,000 hours
Security Slot Type
Kensington security slot
Power Supply
Internal
43 Watt
Microsoft Windows 7
Dimensions & Weight Details
With stand - width: 51.1 cm - depth: 24 cm - height: 63.5 cm - weight: 4.92 kg , Without stand - width: 51.1 cm - depth: 6.6 cm - height: 31 cm - weight: 3.96 kg
ENERGY STAR Certified
20 - 90% (non-condensing)
Diagonal Size: 22in
Response Time: 5ms
Speakers: None
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: ViewSonic
Price Range Ex VAT: 150 - 300
