ViewSonic SWB7051 70" Multi-touch Interactive Display
Quicklinx: 9D09WS00 Mfr#: SWB7051-5
  • 1080p
The ViewSonic 69.5" SWB7051 is the ideal interactive display solution for in-classroom teaching, online training sessions, video conferencing and more. This 6-point touch-enabled Smart White board allows two or more users to simultaneously write and draw directly on the display using their fingers or styli. A Full HD LED screen guarantees crisp and vivid image quality with 400-nit brightness, the SWB7051 provides better visual performance in well-lit rooms. Visually attractive, the SWB7051 has an ergonomic design with a tempered glass overlay, anti-glare treatment and rounded corners.
  • Full HD 1080p for superior pixel performance
    Each smart whiteboard features Full HD 1920 x 1080 resolution to deliver superior pixel-by-pixel performance for a more realistic viewing experience. At this resolution you will experience greater image clarity and detail - qualities that will bring high-definition multimedia content to life.
  • Advanced 6-point touch capability for group interaction
    With 6-point simultaneous touch technology, this display encourages group interaction allowing two users to simultaneously write or draw on the display's surface using styluses or their fingers - both at the same time.
  • Edge-border design improves Windows 8 touch experience
    A unique edge-border design redefines the relationship between the bezel and panel, eliminating any dead angles in a Windows 8 touch environment. This design provides an improved user touch experience. In addition, a pull-out charm bar is easily accessed from the screen's edge, providing simple navigation and access to a variety of applications.
  • Energy-saving LED backlight
    ViewSonic smart whiteboards feature an energy-saving LED backlight with a lifespan of over 30,000 hours - that's more than a decade of durability. This display consumes less power, producing a high ROI and making the SWB7051 a great long-term investment by reducing the cost of ownership.
  • Versatile input selection for flexible connectivity
    With a versatile selection of inputs, the touch display enables you to easily connect and use a variety of digital devices. Additionally, it has an HDMI input that connects to high-definition content sources such as USB, DVI and VGA ports that deliver additional connectivity options.
  • RS232 connectivity for easy multi-device management
    RS232 connectivity enables computers and laptops to be connected to the Smart Whiteboards. RS232 connectivity also allows IT personnel to conveniently manage multiple displays, configure devices and upgrade firmware from a centralized location. This provides organizations the ability to better maintain and control large numbers of displays all from one place.
  • Tough anti-scratch, anti-glare cover
    ViewSonic smart whiteboards feature 7H hardness scratch-resistant glass covers to ensure durability, as well as a consistent and highly responsive touch experience. The Whiteboards also benefit from an anti-glare film layer which improves on-screen visibility in brighter environments.
  • Protective rounded-corner design
    A rounded-corner design provides a safer learning environment for active students preventing injuries in the classroom.
  • A wider range of accessible educational/custom applications
    With a growing list of free and customized Windows 8 apps to choose from, educators now have more teaching options and greater access to various education applications, including reading, writing and math-related apps. Students also have more opportunities to learn and succeed in the classroom.
ViewSonic SWB7051 69.5" LED-backlit LCD display - Full HD
LED-backlit LCD flat panel display with built-in PC and touchscreen
Diagonal Class
69.5"
Resolution
1920 x 1080
Display Format
1080p
Input Video Formats
480p, 720p, 1080p, 480i, 576i, 720i
Video Interface
Component, composite, HDMI, S-Video
HDMI Ports Qty
2 ports
LAN
PC Interface
VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Storage Drive Capacity
500 GB
Storage Capacity
500 GB
USB
4 ports
Remote control, 3 Touch styluses
Voltage
164.9 cm x 9.7 cm x 99.9 cm
75 kg
Diagonal Class
69.5"
Combined With
Built-in PC and touchscreen
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI Ports Qty
2 ports
PC Interface
VGA (HD-15)
HDCP Compatible
Modes
Whiteboard mode
Timer Functions
Sleep
Design
Rounded-corner design
Protection
Anti-scratch display
164.9 cm
9.7 cm
99.9 cm
75 kg
Enclosure Colour
Display
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
LED backlight
Coating
Anti-glare, 7H Hard
Image Contrast Ratio
4000:1
Brightness
400 cd/m²
Viewing Angle
88°
Viewing Angle (Vertical)
88°
Touchpoints Qty
6
Response Time
6 ms
Backlight Life
50,000 hour(s)
Key lock
Stands & Mounts
Flat Panel Mount Interface
600 x 600 mm
Video Features
Input Video Formats
Media Player
USB Port
USB Ports Qty
4
Configuration
Intel Core i5 - 4 GB - 500 GB
500 GB
Operating System
Windows 8
Remote Control
Remote control
Audio System
Audio Controls
Sound mode, balance, bass, treble
Speaker System
2 speakers
Output Power / Total
30 Watt
Speakers
2 x main channel speaker - 15 Watt
Network & Internet Multimedia
LAN
LAN Protocol
Gigabit Ethernet
Connector Type
2 x HDMI , 2 x VGA input , 2 x audio input , S-Video input , Composite video input , Composite video output , Audio input , Component video input , USB , SPDIF input , Serial input , Audio line-out , Microphone , VGA output , LAN , 4 x USB 2.0 , USB
3 Touch styluses
VGA cable , USB cable , Audio cable
CCC
Power supply
Input Voltage
Width (Shipping)
178.5 cm
Depth (Shipping)
27.5 cm
Height (Shipping)
114 cm
Weight (Shipping)
85 kg
20 - 80% (non-condensing)
