The ViewSonic 69.5" SWB7051 is the ideal interactive display solution for in-classroom teaching, online training sessions, video conferencing and more. This 6-point touch-enabled Smart White board allows two or more users to simultaneously write and draw directly on the display using their fingers or styli. A Full HD LED screen guarantees crisp and vivid image quality with 400-nit brightness, the SWB7051 provides better visual performance in well-lit rooms. Visually attractive, the SWB7051 has an ergonomic design with a tempered glass overlay, anti-glare treatment and rounded corners.
Full HD 1080p for superior pixel performance
Each smart whiteboard features Full HD 1920 x 1080 resolution to deliver superior pixel-by-pixel performance for a more realistic viewing experience. At this resolution you will experience greater image clarity and detail - qualities that will bring high-definition multimedia content to life. -
Advanced 6-point touch capability for group interaction
With 6-point simultaneous touch technology, this display encourages group interaction allowing two users to simultaneously write or draw on the display's surface using styluses or their fingers - both at the same time. -
Edge-border design improves Windows 8 touch experience
A unique edge-border design redefines the relationship between the bezel and panel, eliminating any dead angles in a Windows 8 touch environment. This design provides an improved user touch experience. In addition, a pull-out charm bar is easily accessed from the screen's edge, providing simple navigation and access to a variety of applications. -
Energy-saving LED backlight
ViewSonic smart whiteboards feature an energy-saving LED backlight with a lifespan of over 30,000 hours - that's more than a decade of durability. This display consumes less power, producing a high ROI and making the SWB7051 a great long-term investment by reducing the cost of ownership. -
Versatile input selection for flexible connectivity
With a versatile selection of inputs, the touch display enables you to easily connect and use a variety of digital devices. Additionally, it has an HDMI input that connects to high-definition content sources such as USB, DVI and VGA ports that deliver additional connectivity options. -
RS232 connectivity for easy multi-device management
RS232 connectivity enables computers and laptops to be connected to the Smart Whiteboards. RS232 connectivity also allows IT personnel to conveniently manage multiple displays, configure devices and upgrade firmware from a centralized location. This provides organizations the ability to better maintain and control large numbers of displays all from one place. -
Tough anti-scratch, anti-glare cover
ViewSonic smart whiteboards feature 7H hardness scratch-resistant glass covers to ensure durability, as well as a consistent and highly responsive touch experience. The Whiteboards also benefit from an anti-glare film layer which improves on-screen visibility in brighter environments. -
Protective rounded-corner design
A rounded-corner design provides a safer learning environment for active students preventing injuries in the classroom. -
A wider range of accessible educational/custom applications
With a growing list of free and customized Windows 8 apps to choose from, educators now have more teaching options and greater access to various education applications, including reading, writing and math-related apps. Students also have more opportunities to learn and succeed in the classroom.
- ViewSonic SWB7051 69.5" LED-backlit LCD display - Full HD
- Product Type
- LED-backlit LCD flat panel display with built-in PC and touchscreen
- Diagonal Class
- 69.5"
- Black
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Input Video Formats
- 480p, 720p, 1080p, 480i, 576i, 720i
- Video Interface
- Component, composite, HDMI, S-Video
- HDMI Ports Qty
- 2 ports
- Connectivity
- LAN
- PC Interface
- VGA (HD-15)
- HDCP Compatible
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- Storage Drive Capacity
- 500 GB
- Storage Capacity
- 500 GB
- USB
- 4 ports
- Included Accessories
- Remote control, 3 Touch styluses
- Voltage
- AC 120/230 V (50/60 Hz)
- 164.9 cm x 9.7 cm x 99.9 cm
- 75 kg
- Product Type
- Diagonal Class
- 69.5"
- Combined With
- Built-in PC and touchscreen
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI Ports Qty
- 2 ports
- PC Interface
- VGA (HD-15)
- HDCP Compatible
- Modes
- Whiteboard mode
- Timer Functions
- Sleep
- Design
- Rounded-corner design
- Protection
- Anti-scratch display
- 164.9 cm
- 9.7 cm
- 99.9 cm
- 75 kg
- Enclosure Colour
- Black
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight
- Coating
- Anti-glare, 7H Hard
- Image Contrast Ratio
- 4000:1
- Brightness
- 400 cd/m²
- Viewing Angle
- 88°
- Viewing Angle (Vertical)
- 88°
- Touchpoints Qty
- 6
- Response Time
- 6 ms
- Backlight Life
- 50,000 hour(s)
- Key lock
Stands & Mounts
- Flat Panel Mount Interface
- 600 x 600 mm
Video Features
Media Player
- USB Port
- USB Ports Qty
- 4
- Configuration
- Intel Core i5 - 4 GB - 500 GB
- 500 GB
- Operating System
- Windows 8
Remote Control
- Remote control
Audio System
- Audio Controls
- Sound mode, balance, bass, treble
- Speaker System
- 2 speakers
- Output Power / Total
- 30 Watt
- Speakers
- 2 x main channel speaker - 15 Watt
Network & Internet Multimedia
- Connectivity
- LAN
- LAN Protocol
- Gigabit Ethernet
- Connector Type
- 2 x HDMI , 2 x VGA input , 2 x audio input , S-Video input , Composite video input , Composite video output , Audio input , Component video input , USB , SPDIF input , Serial input , Audio line-out , Microphone , VGA output , LAN , 4 x USB 2.0 , USB
- 3 Touch styluses
- Cables Included
- VGA cable , USB cable , Audio cable
- CCC
- Power Device
- Power supply
- Input Voltage
- Width (Shipping)
- 178.5 cm
- Depth (Shipping)
- 27.5 cm
- Height (Shipping)
- 114 cm
- Weight (Shipping)
- 85 kg
- 0 °C
- 40 °C
- 20 - 80% (non-condensing)
