ViewSonic SC-Z55 - USFF - Tera2321 - RAM 512 MB - no HDD - GigE - no OS
Quicklinx: 9PMFWS00 Mfr#: SC-Z55_BK_EU_0
The ViewSonic SC-Z55 Zero Client is the perfect solution for companies seeking a seamless desktop experience with ultra-high security and reliability in networks based on VMware technology networks. This is a true Zero Client device and features no local memory or moving parts for the ultimate in energy savings and reliability. Based on the Teradici Tera 2321, with hardware accelerated PCoIP, the VMware certified design guarantees performance and compatibility in your network. Dual video outputs provide flexibility for supporting dual 1080p digital displays, and the eco-friendly design consumes less energy than standard PCs. The SC-Z55 is also a space saver. It easily attaches to your VESA-ready monitor with an included VESA mounting bracket. ViewSonic's Zero Clients are the smart choice for optimizing your virtual desktop deployment.
  • True personal PC experience
    The SC-Z55 supports 2D and 3D graphic-intensive applications and a rich multimedia experience at full frame rates over Gigabit Ethernet. This is the no-compromise solution for demanding users.
  • Optimized power for VMware view
    Teradici's Tera2321 is the most advanced processor for VMware-based virtualization. Experience all of your applications with an ultra-fast response time.
  • Easy deployment and management
    Deploy users up to 5-times faster than traditional PC-based clients, and enjoy on going simplified management without the need for constant patches and system updates.
  • Dual display productivity
    With dual digital outputs, the SC-Z55 supports either two 1080p displays, or one QHD display for increased productivity.
  • Simplified and Secure management
    The Teradici PCoIP Management Console provides for centralized deployment and management. With web-based access, administrators will be able to configure, update, manage, and even remotely control the power state for all of their PCoIP-based zero clients throughout the network.
  • Low total cost of ownership
    All of the benefits of a virtual desktop deployment can be realized with ViewSonic's SC-Z55 Zero Client. From simple and quick deployment, enhanced security with no local HDD, increased reliability and higher productivity - the SC-Z55 is an efficient and low-cost choice for virtualizing desktops.
ViewSonic SC-Z55 - USFF Tera2321 - 512 MB - no HDD
Thin client - ultra small form factor - PC over IP (PCoIP) technology, VMware Ready
Region: Europe
1 x Teradici Tera2321
RAM
512 MB DDR3 SDRAM
Flash Memory
0 GB
Hard Drive
No HDD
Optical Storage
No optical drive
GigE
OS Provided
No operating system
Software Included
ViewSonic Wizard, ViewSonic Device Manager, ViewSonic Client Setup
3.95 cm x 10.3 cm x 14.3 cm
500 g
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years
Thin client
Product Form Factor
Ultra small form factor
Region: Europe
Processor / Chipset
CPU
Teradici Tera2321
CPU Qty
1
RAM
Installed Size
512 MB
DDR3 SDRAM
Effective Memory Speed
1066 MHz
Flash Memory
Flash Memory
0 GB
Hard Drive
No HDD
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Video Interfaces
VGA, DVI
Max Monitors Supported
2
Wake on LAN (WoL), DHCP support
4 x USB 2.0 (2 front, 2 rear) , 1 x DVI-D , 1 x DVI-I , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in (1 in front) , 1 x headphones (1 in front)
VESA mounting kit
DVI-VGA adapter
VESA Mounting Interface
100 x 100 mm
FCC, RoHS, WEEE, REACH, NRTL
Power adapter
Power Provided
15 Watt
7 Watt
Operating System / Software
OS Provided
No operating system
Software
Sustainability Information
ENERGY STAR Certified
3.95 cm
10.3 cm
14.3 cm
500 g
10 - 90% (non-condensing)
