The ViewSonic SC-Z55 Zero Client is the perfect solution for companies seeking a seamless desktop experience with ultra-high security and reliability in networks based on VMware technology networks. This is a true Zero Client device and features no local memory or moving parts for the ultimate in energy savings and reliability. Based on the Teradici Tera 2321, with hardware accelerated PCoIP, the VMware certified design guarantees performance and compatibility in your network. Dual video outputs provide flexibility for supporting dual 1080p digital displays, and the eco-friendly design consumes less energy than standard PCs. The SC-Z55 is also a space saver. It easily attaches to your VESA-ready monitor with an included VESA mounting bracket. ViewSonic's Zero Clients are the smart choice for optimizing your virtual desktop deployment.
True personal PC experience
The SC-Z55 supports 2D and 3D graphic-intensive applications and a rich multimedia experience at full frame rates over Gigabit Ethernet. This is the no-compromise solution for demanding users. -
Optimized power for VMware view
Teradici's Tera2321 is the most advanced processor for VMware-based virtualization. Experience all of your applications with an ultra-fast response time. -
Easy deployment and management
Deploy users up to 5-times faster than traditional PC-based clients, and enjoy on going simplified management without the need for constant patches and system updates. -
Dual display productivity
With dual digital outputs, the SC-Z55 supports either two 1080p displays, or one QHD display for increased productivity. -
Simplified and Secure management
The Teradici PCoIP Management Console provides for centralized deployment and management. With web-based access, administrators will be able to configure, update, manage, and even remotely control the power state for all of their PCoIP-based zero clients throughout the network. -
Low total cost of ownership
All of the benefits of a virtual desktop deployment can be realized with ViewSonic's SC-Z55 Zero Client. From simple and quick deployment, enhanced security with no local HDD, increased reliability and higher productivity - the SC-Z55 is an efficient and low-cost choice for virtualizing desktops.
- ViewSonic SC-Z55 - USFF Tera2321 - 512 MB - no HDD
- Thin client - ultra small form factor - PC over IP (PCoIP) technology, VMware Ready
- Localisation
- Region: Europe
- Processor
- 1 x Teradici Tera2321
- RAM
- 512 MB DDR3 SDRAM
- Flash Memory
- 0 GB
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Networking
- GigE
- OS Provided
- No operating system
- Software Included
- ViewSonic Wizard, ViewSonic Device Manager, ViewSonic Client Setup
- 3.95 cm x 10.3 cm x 14.3 cm
- 500 g
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years
- Thin client
- Product Form Factor
- Ultra small form factor
- Localisation
- Region: Europe
Processor / Chipset
- CPU
- Teradici Tera2321
- CPU Qty
- 1
RAM
- Installed Size
- 512 MB
- Technology
- DDR3 SDRAM
- Effective Memory Speed
- 1066 MHz
Flash Memory
- Flash Memory
- 0 GB
Hard Drive
- No HDD
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Video Interfaces
- VGA, DVI
- Max Monitors Supported
- 2
- Data Link Protocol
- Wake on LAN (WoL), DHCP support
- 4 x USB 2.0 (2 front, 2 rear) , 1 x DVI-D , 1 x DVI-I , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in (1 in front) , 1 x headphones (1 in front)
- Included Accessories
- VESA mounting kit
- Cables Included
- DVI-VGA adapter
- VESA Mounting Interface
- 100 x 100 mm
- FCC, RoHS, WEEE, REACH, NRTL
- Power adapter
- Power Provided
- 15 Watt
- 7 Watt
Operating System / Software
- OS Provided
- Software
Sustainability Information
- ENERGY STAR Certified
- 3.95 cm
- 10.3 cm
- 14.3 cm
- 500 g
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
