ViewSonic SC-T45 Intel Atom N2800 2GB DDR3 4GB Flash Windows 7
Quicklinx: 9PMDWS00 Mfr#: SC-T45_BK_EU_0
  • Atom
The ViewSonic SC-T45 thin client PC uses the powerful Intel Atom processor. The SC-T45 is optimized for all of the major remote networking protocols including Citrix ICA/HDX, VMware PCoIP, and Microsoft RemoteFX - making it a versatile virtualization solution with endless possibilities. The SC-T45 has the horsepower needed to handle a large portion of local processing and graphics rendering, and the flexibility to operate as a stateless device in a VDI-based infrastructure. The SC-T45 is also an energy and space saver, consuming only 14 W of power and easily attaching to your VESA-ready monitor with the included VESA bracket. The SC-T45 thin client is the perfect solution for companies seeking the benefits of true PC-like performance, along with simplified management and lower total cost of ownership. ViewSonic's thin clients are the smart choice for optimizing your virtual desktop deployment.
  • Powerful computing combination
    With an Intel Atom processor, the SC-T45 is equipped to handle the highest demands of both virtual and local processing, including the most 2D/3D graphic intensive applications.
  • Easy deployment and management
    Deploy users up to 5 times faster than traditional PC-based clients, and enjoy ongoing simplified management without the need for constant patches and system updates.
  • Flexible design
    Future-proof your network with this flexible thin client and rest assured that you will be supported even if your virtualization needs change later. The SC-T45 is ViewSonic's most flexible offering for supporting MS, Citrix, or VMware view.
  • Low total cost of ownership
    With easier and faster deployment, simplified management, and increased reliability and security, the benefits and efficiency of ViewSonic's SC-T45 lead to a lower cost of ownership.
ViewSonic SC-T45 - USFF - Atom N2800 1.86 GHz - 2 GB - flash 4 GB
Thin client - ultra small form factor - PC over IP (PCoIP) technology, Citrix Ready, VMware Ready
Region: Europe
1 x Intel Atom N2800 / 1.86 GHz (Dual-Core)
Cache Memory
1 MB
Cache Per Processor
1 MB
RAM
2 GB DDR3 SDRAM
Hard Drive
Flash 4 GB
Optical Storage
No optical drive
GigE
OS Provided
Microsoft Windows Embedded Standard 7
Software Included
ViewSonic Wizard, ViewSonic Device Manager, ViewSonic Client Setup
3.95 cm x 10.3 cm x 14.3 cm
500 g
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years
Thin client
Recommended Use
Small business, corporate business, education, government
Product Form Factor
Ultra small form factor
Region: Europe
Processor / Chipset
CPU
Intel Atom N2800
Clock Speed
1.86 GHz
Number of Cores
Dual-Core
CPU Qty
1
Chipset Type
Intel NM10 Express
Cache Memory
Installed Size
1 MB
Cache Per Processor
1 MB
RAM
Installed Size
2 GB
DDR3 SDRAM
Effective Memory Speed
1066 MHz
Hard Drive
Flash
4 GB
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Video Interfaces
VGA, DVI
Max Monitors Supported
2
Integrated
Wake on LAN (WoL), DHCP support
4 x USB 2.0 (2 front, 2 rear) , 1 x DVI-D , 1 x VGA , 1 x LAN (Gigabit Ethernet) - RJ-45 , 1 x audio line-in - mini-jack (1 in front) , 1 x headphones - mini-jack (1 in front)
VESA mounting kit
VESA Mounting Interface
100 x 100 mm
FCC, RoHS, WEEE, REACH, NRTL
Power adapter
Power Provided
36 Watt
14 Watt
Operating System / Software
OS Provided
Software
Sustainability Information
ENERGY STAR Certified
3.95 cm
10.3 cm
14.3 cm
500 g
10 - 90% (non-condensing)
