ViewSonic's industry leading projector, the Pro8520HD, is a Full HD 1080p model that delivers superior and stunning HD image quality onto 30~300" screen. With 5,000 lumens, the Pro8520HD ensures every pixel will stay crystal clear on the large venue even with the wide range of brightness settings. The Pro8520HD supports a Crestron RoomView network management system that efficiently controls and manages all the projectors in the system from a central terminal. Through a RJ45 connection, the Pro8520HD can simultaneously display inputs from 4 different computer screens, provided all devices are connected to the same intranet. This facilitates the development of synergy among the participants. For a PC less presentation, it can also be operated by just plugging in an USB flash to enjoy the content immediately. With 1.5x optical zoom, it enlarges the screen image and fit in anywhere. The versatile interfaces, such as HDMI, RGB, S-video, component inputs and integrated speakers and microphone, allow the Pro8520HD to be used as an audiovisual stereo, making it the optimal solution for projection in large lecture rooms, conference rooms, and public demo rooms.
Vivid and crystal clear Full HD 1080p projection in any environment
ViewSonic's Pro8520HD boasts Full HD 1080p native resolution with sophisticated and crisp images. With ultrahigh 5,000 lumens brightness, you'll experience the most lifelike and vibrant images ever, even in bright environments. -
LAN projection increases the flexibility of the presentation
Through a LAN connection, the Pro8520 can connect with up to four PCs to simultaneously display all screens in a single projection. This allows users to share multiple resources to efficiently communicate in educational and professional environments. -
Wireless display via WiFi
By plugging-in an optional WiFi USB dongle, such as ViewSonic's WPD-100, into the Pro8520HD, you can now connect any Wi-Fi equipped laptop to the Pro8520HD for image and audio transmission. -
Wide 1.5x optical zoom adjustment
The Pro8520HD features a 1.5x all-glass optical zoom lens to deliver high brightness, sharp images, and superior color performance. This zoom lens enables it to cast images up to 40% larger than a conventional projector, rendering greater flexibility when mounted to the ceiling. An USB reader creates PC-less presentationThis projector supports a USB reader that accesses files directly from an USB flash drive, rendering a PC-free projection. -
Crestron RoomView provides an advanced, real-time alert system that simplifies maintenance efforts by sending updates on the power status, lamp lifespan, and unit presence directly to your PC. It also automates device functions such as power on/off, and broadcasts urgent messages via closed captioning. -
Versatile digital interface and input/output
The Pro8520HD features a wide range of compatibility for high-definition content input including HDMI, composite, S-video, and VGA input. The pair of 10W speakers, complemented with a microphone input, provides high volume audio without the need for external speakers. -
Easy and quick connection via USB display
The Pro8520HD carries an USB display function that provides an alternative way to set up your presentation easily and quickly by connecting your laptop to the Pro8520HD through an USB cable.
- ViewSonic Pro8520HD - DLP projector
- DLP projector - 1080p
- Microdisplay
- DMD Chip
- Brightness
- 5000 lumens
- Contrast Ratio
- 15000:1 (dynamic)
- Resolution
- Full HD (1920 x 1080)
- Native Aspect Ratio
- 16:9
- Bulb type
- 350 Watt
- Bulb life cycle
- Up to 2500 hour(s) - normal mode , Up to 3000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, PAL 60, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - internal
- Power
- AC 120/230 V (50/60 Hz)
- 33.3 cm x 26.3 cm x 12.2 cm
- 3.86 kg
- Networking
- Ethernet
Projector
- Microdisplay
- DMD Chip
- Brightness
- 5000 lumens
- Contrast Ratio
- 15000:1 (dynamic)
- Image Size
- 76 cm - 760 cm
- Projection Distance
- 0.9 m - 9.4 m
- Throw Ratio
- 1.4 - 2.14:1
- Resolution
- 16:9
- Max Sync Rate (V x H)
- 85 Hz x 91 kHz
- Bulb type
- 350 Watt
- Bulb life cycle
- OSD Languages
- Thai, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Japanese, Korean
- 6-segment colour wheel, BrilliantColor, USB host function, Crestron RoomView
Lens
- Zoom Factor
- 1.5x
- Keystone Correction Type
- Digital
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -20 / +20
Video Input
- TV System
- PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, PAL 60, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
- Video Modes
Speakers
- Internal
- Sound Output Mode
- Stereo
- Output Power / Channel
- 10 Watt
- Speakers
- 2 x right / left channel
- 2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 2 x HDMI input - 19 pin HDMI Type A , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x audio line-in - RCA x 2 , 1 x microphone - mini-phone 3.5 mm , 1 x network - RJ-45 , 1 x remote control - 9 pin D-Sub (DB-9) , 1 x USB - 4 pin USB Type A , 1 x USB - mini-USB Type B
- Included Accessories
- Carrying case, lens cover, wireless remote control
- Cables Included
- 1 x VGA cable - 1.8 m , 1 x HDMI cable
- Security Features
- Voltage Required
- Software Included
- ViewSonic Wizard
- 33.3 cm
- 26.3 cm
- 12.2 cm
- 3.86 kg
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
