ViewSonic PJD7835HD 1920x1080 Full HD 3500 Lumens Projector
Quicklinx: C3J0WS00 Mfr#: PJD7835HD
The ViewSonic LightStream PJD7835HD Full HD projector features high brightness and excellent contrast, native 1080p resolution and optimal throw ratio for larger screens from shorter distances. Flexible connectivity is provided by HDMI ports, which also offer support for Wi-Fi dongles. Outstanding color & sound performance is powered by a special SuperColor feature and SonicExpert audio technology, whilst a hidden HDMI-MHL compartment and a rear cable cover complete the sleek design.
  • Full HD delivers extremely fine picture quality
    This ViewSonic projector features Full HD 1080p native resolution for extra sharp and clear picture. It is perfect for watching most types of personal high-definition content including movies, videos, sports, games, and TV. HD is also now demanded in numerous business applications like finance, medical and design.
  • HDMI ports with 3D support
    Equipped with HDMI ports, this projector is perfect for connecting to any HDMI-enabled device such as laptops, tablets, games consoles and DVD or Blu-ray players. It also supports 3D images directly from 3D sources.
  • Larger screens from shorter distances
    A shorter than normal throw ratio projects large images from reduced distances in small rooms. The lens with optical zoom also provides positioning flexibility by creating significantly larger screens without having to move the projector.
  • Perfectly shaped ages
    Horizontal and vertical keystone correction and 4 corner adjustment features eliminate crooked and distorted images for a perfectly proportioned picture every time.
  • Beautiful design with rear cable cover
    With its dot texture finish, curved edges and tactile keypad this LightStream projector stands out from the competition. A concealed HDMI-MHL port and rear cable cover provides security and completes the look by hiding cable clutter and exposed ports.
  • SuperColor technology for superb color accuracy
    ViewSonic's SuperColor technology offers a wider color range than conventional DLP projectors for true-to-life color performance in any light, while the SuperColor technology maximizes brightness.
  • SonicExpert technology for beautiful sound
    ViewSonic's SonicExpert technology incorporates a ported speaker chamber and a more powerful amplifier to deliver much higher volume and outstanding sound.
  • Quiet operation
    A built-in thermal sensor control system and a large fan effectively keep the projector cool while intelligently minimizing fan speed, reducing noise and saving on energy consumption.
  • Easy-to-use preset color modes
    With 5 preset color modes, users can choose the best one to suit their material: Brightest, Dynamic, Standard, ViewMatch or Movie.
ViewSonic LightStream PJD7835HD - DLP projector - 3D - black
DLP projector - 1080p
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Speaker
United States
Brightness
3500 lumens
Contrast Ratio
22000:1 (dynamic)
Resolution
Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Colour Support
1.07 billion colours
Bulb type
250 Watt
Bulb life cycle
Up to 3500 hour(s) - normal mode , Up to 8000 hour(s) - economic mode
Video Input
RGB, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, PAL 60, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM D/K, SECAM B/G, M-NTSC, SECAM L1)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
315 Watt
36.2 cm x 23.1 cm x 10.9 cm
2.8 kg
3-year warranty
3D Capable
Built-in Devices
Speaker
Enclosure Colour
United States
Projector
Brightness
3500 lumens
Contrast Ratio
22000:1 (dynamic)
Image Size
76 cm - 762 cm
Projection Distance
0.7 m - 9.7 m
Throw Ratio
1.1 - 1.5:1
Resolution
Full HD - Full HD (1920 x 1080) (native) / 1920 x 1080 (resized)
Native Aspect Ratio
16:9
Colour Support
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
250 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
Super Color, DynamicEco Mode, SonicExpert
Lens
Focus Type
Manual
Zoom Type
Manual
Zoom Factor
1.36x
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, MHL
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
Speakers
1 x mixed channel
1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x microphone - mini-phone 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x audio line-in - mini-phone 3.5 mm , 1 x audio line-out - mini-phone 3.5 mm , 1 x USB - mini-USB Type B , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x USB - 4 pin USB Type A
Wireless remote control
1 x VGA cable
Security Features
UL, TUV GS, C-Tick, SASO, TUV S, CB, EMC, DOC, PSB, FCC, RoHS, KCC, WEEE, REACH, UkrSEPRO, KC, ERP, CECP, EAC, SVHC, CoC
Power Source
AC
315 Watt
Power Consumption Stand by
0.5 Watt
Software Included
ViewSonic Wizard
36.2 cm
23.1 cm
10.9 cm
2.8 kg
Limited warranty - 3 years , Limited warranty - lamp - 1 year , Limited warranty - express exchange - 1 year
10 - 90% (non-condensing)
Sound Emission
32 dB
28 dB
