Product
Brand
ViewSonic PJD7835HD 1920x1080 Full HD 3500 Lumens Projector
Quicklinx: C3J0WS00 Mfr#: PJD7835HD
The ViewSonic LightStream PJD7835HD Full HD projector features high brightness and excellent contrast, native 1080p resolution and optimal throw ratio for larger screens from shorter distances. Flexible connectivity is provided by HDMI ports, which also offer support for Wi-Fi dongles. Outstanding color & sound performance is powered by a special SuperColor feature and SonicExpert audio technology, whilst a hidden HDMI-MHL compartment and a rear cable cover complete the sleek design.
ViewSonic LightStream PJD7835HD - DLP projector - portable - 3D
DLP projector - High Definition 1080p
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Speaker
United States
Brightness
3500 lumens
Contrast Ratio
22000:1 (dynamic)
Resolution
Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Colour Support
1.07 billion colours
Bulb type
250 Watt
Bulb life cycle
Up to 3500 hour(s) / up to 8000 hour(s) (economic mode)
Video Input
RGB, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, PAL 60, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM D/K, SECAM B/G, M-NTSC, SECAM L1)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
315 Watt
36.2 cm x 23.1 cm x 10.9 cm
2.8 kg
3 years warranty
DLP projector - HD 1080p
3D Capable
Built-in Devices
Speaker
Enclosure Colour
United States
Projector
Brightness
3500 lumens
Contrast Ratio
22000:1 (dynamic)
Image Size
76 cm - 762 cm
Projection Distance
0.7 m - 9.7 m
Throw Ratio
1.1 - 1.5:1
Resolution
Full HD - Full HD (1920 x 1080) (native) / 1920 x 1080 (resized)
Native Aspect Ratio
16:9
Colour Support
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
250 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
Super Color, DynamicEco Mode, SonicExpert
Lens
Focus Type
Manual
Zoom Type
Manual
Zoom Factor
1.36x
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, MHL
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
Speakers
1 x mixed channel
1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x microphone - mini-phone 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x audio line-in - mini-phone 3.5 mm , 1 x audio line-out - mini-phone 3.5 mm , 1 x USB - mini-USB Type B , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x USB - 4 pin USB Type A
Wireless remote control
1 x VGA cable
Security Features
UL, TUV GS, C-Tick, SASO, TUV S, CB, EMC, DOC, PSB, FCC, RoHS, KCC, WEEE, REACH, UkrSEPRO, KC, ERP, CECP, EAC, SVHC, CoC
Power Source
AC
Nominal Voltage
315 Watt
Power Consumption Stand by
0.5 Watt
Software Included
ViewSonic Wizard
36.2 cm
23.1 cm
10.9 cm
2.8 kg
Limited warranty - 3 years , Limited warranty - lamp - 1 year , Limited warranty - express exchange - 1 year
10 - 90% (non-condensing)
Sound Emission
32 dB
28 dB
