The ViewSonic LightStream PJD6352LS networkable projector features 3200 lumens, native XGA 1024x768 resolution, and an intuitive, user-friendly design. Exclusive SuperColor technology offers a wider color range for true-to-life image projection in any light, while SonicExpert, ViewSonic's proprietary sound enhancement technology, powers a 10W speaker to deliver incredibly clear and audible sound. PortAll - a hidden compartment with an integrated and secure MHL/HDMI port - lets you discretely stream multimedia content from a wireless dongle, or lets you connect to other devices via an HDMI cable. A cable management hood eliminates unsightly cable clutter, and a top lamp door enables easy access for lamp maintenance. A short throw lens with a 0.61 throw ratio offers large projection images for smaller rooms. With HV keystone, corner adjustment, and easy network management, the PJD6352LS provides flexible setup. Designed with smarter features and extensive connectivity, the networkable short throw PJD6352LS is ideal for use in education and corporate environments.
SuperColor
ViewSonic's proprietary SuperColor Technology offers a wider color range than conventional projectors, ensuring that users enjoy more realistic and accurate colors. With an exclusive color wheel design and dynamic lamp control capabilities, SuperColor Technology projects images with reliable and true-to-life color performance, in both bright and dark environments, without sacrificing image quality. Projectors that increase the white color segment to enhance brightness often suffer from washed out images. Striking an ideal balance, ViewSonic's SuperColor 6-Segment Color Wheel decreases the white segment while increasing the yellow and cyan segments - for images that are both exceptionally bright and well-saturated. -
PortAll: secure MHL/HDMI port
This projector includes ViewSonic's exclusive PortAll feature - a hidden compartment with an integrated and secure MHL/HDMI port that lets you discretely stream multimedia content from a wireless dongle, or lets you connect to other devices via an HDMI cable. -
Network capable
All LightStream PJD6 projectors come equipped with Crestron RoomView Express, an easy-to-use network management system that lets administrators remotely monitor and control over 250 LightStream projectors from a single PC. -
Smart design
The cable management hood connects onto the back of the projector to hide unsightly cable clutter and exposed ports. An easy-access top lamp door enables simple lamp maintenance and replacement. -
SonicExpert technology
This LightStream projector is designed with ViewSonic's proprietary SonicExpert technology that incorporates an enlarged speaker chamber and a more powerful amplifier to deliver a full 20Hz - 20Khz sound range. A 10-watt speaker captivates your audience with immersive sound. -
Large images in small spaces
A short throw lens with a 0.61 throw ratio projects large, stunning images from short distances in small rooms. -
Dual 3D Blu-ray ready HDMI inputs
Designed with two HDMI ports, this projector can display 3D images directly from 3D Blu-ray players - perfect for connecting to any HDMI-enabled device. -
Balanced color and brightness
A choice of 5 unique view settings provides great viewing experience in any environment regardless of ambient light. -
Horizontal and vertical keystone correction
Horizontal and vertical keystone correction and a corner adjustment feature eliminate crooked and distorted images for a perfectly proportioned picture every time. -
Programmable remote control
A programmable hotkey "MyButton" can be configured to launch the commonly used functions. Control up to eight projectors in the same venue or from a mobile device via free V-remote app.
- ViewSonic LightStream PJD6352LS - DLP projector - short-throw - 3D
- DLP projector
- 3D Capable
- Yes (3D glasses sold separately)
- Built-in Devices
- Keypad
- Bundled Services
- 1 year Express Exchange Service
- Localisation
- Americas
- Brightness
- 3500 ANSI lumens
- Contrast Ratio
- 22000:1 (dynamic)
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Colour Support
- 1.07 billion colours (30-bit)
- Lens
- Short-throw fixed lens
- Bulb type
- 210 Watt
- Bulb life cycle
- Up to 4000 hours - normal mode , Up to 10000 hours - economic mode
- Video Input
- RGB, S-Video, composite video
- Video Modes
- 720p, 1080p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 330 Watt
- 31.6 cm x 22.8 cm x 10.37 cm
- 2.2 kg
- 3-year warranty
- DLP projector
- 3D Capable
- Built-in Devices
- Keypad
- Bundled Services
- Networking
- Ethernet
- Localisation
- Americas
Projector
- Brightness
- 3500 ANSI lumens
- Contrast Ratio
- 22000:1 (dynamic)
- Image Size
- 127 cm - 635 cm
- Projection Distance
- 0.61 m - 3.09 m
- Throw Ratio
- 0.61:1
- Resolution
- XGA - XGA (1024 x 768) (native) / 1920 x 1080 (resized)
- 4:3
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 102 kHz
- Bulb type
- 210 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction, zoom, focus
- 6-segment colour wheel, Crestron RoomView, MHL compliance, SonicExpert, PortAll, ViewSonic SuperColor
Lens
- Focus Type
- Manual
- Zoom Type
- Manual
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -30 / +30
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video, MHL
- Video Modes
- 720p, 1080p
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 10 Watt
- Speakers
- 1 x mixed channel
- 2 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 2 x audio line-in - mini-phone 3.5 mm , 1 x audio line-out - mini-phone 3.5 mm , 1 x USB - mini-USB Type B , 1 x HDMI input - 19 pin HDMI Type A , 1 x network - RJ-45 , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A
- Included Accessories
- Remote control with laser pointer
- Cables Included
- 1 x VGA cable
- Security Features
- Security Slot Type
- Kensington security slot
- UL, TUV GS, C-Tick, cUL, ICES-003, SASO, TUV S, CB, CCC, EMC, DOC, PSB, FCC, RoHS, KCC, WEEE, REACH, UkrSEPRO, KC, ERP, EAC, SVHC, CoC
- Power Source
- AC
- Voltage Required
- 330 Watt
- Power Consumption Stand by
- 0.5 Watt
- Software Included
- ViewSonic Wizard
- 31.6 cm
- 22.8 cm
- 10.37 cm
- 2.2 kg
- Shipping Width
- 41 cm
- Shipping Depth
- 45 cm
- Shipping Height
- 22.5 cm
- Shipping Weight
- 4 kg
- Limited warranty - parts and labour - 3 years , Limited warranty - lamp - 1 year
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
- Sound Emission
- 32 dB
- Sound Emission (Economic Mode)
- 27 dB
