ViewSonic PJD6352 1024x768 XGA 3500 Lumens LCD 3D Projector
Quicklinx: B7SDWS00 Mfr#: PJD6352
The ViewSonic networkable LightStream PJD6352 features 2x HDMI, 3,500 lumens, high resolution 4:3 (XGA 1024x768), majestic style and thoughtfully intuitive design. It also features a throw ratio of 1.51-1.97 which is ideal for replacing 3LCD projectors like EPSON, NEC, Hitachi, Panasonic, Sony etc.
Exclusive SuperColor 6-Segment Color Wheel maximizes color saturation and brightness for true-to-life image projection in any light, while exclusive SonicExpert speaker design powering a 10W speaker to deliver incredibly clear and audible sound.
A neatly enclosed HDMI-MHL (Media High-Definition Link) compartment supports wireless media streaming from HDMI dongles or MHL connectors (like ViewSonic's WPG-300 and Google Chromecast), while a cable management hood connects onto the back of the projector to eliminate unsightly cable clutter.
With horizontal and vertical keystone correction, corner adjustment, 1.3x optical zoom, and easy network management, the PJD6352 provides flexible setup.
  • Epson, NEC, Hitachi (3LCD projectors) distance match
    With a throw ratio ranging from 1.51 to 1.97, this projector is primed to replace typical 3LCD projectors (EPSON, NEC, Hitachi, Panasonic, Sony) without having to move or re-install existing ceiling mounts. Also equipped with a 1.3x optical zoom lens, this projector provides mounting flexibility with a wider throw distance range.
  • 2x HDMI with 3D support
    Equipped with two HDMI ports, this projector is perfect for connecting to any HDMI-enabled device such as laptops, tablets, games consoles and DVD or Blu-ray players. It also supports 3D images directly from 3D sources.
  • Beautiful design with rear cable cover
    With its matte hairline finish, curved edges and tactile keypad this LightStream Projector stands out from the competition. A cable cover completes the look by hiding cable clutter and exposed ports at the rear.
  • Bright images less lighting limitations
    Packed with 3,500 lumens and a high contrast ratio, the PJD6352 is guaranteed to produce bright images in any environment - even in rooms with high ambient light.
  • SuperColor
    ViewSonic's proprietary SuperColor technology offers a wider color range than conventional projectors for true-to-life color performance in any light. SuperColor 6-segment color wheel maximizes brightness Increased by 15% or more with the highest color saturation over others in the same class.
  • SonicExpert Technology for best-in-class sound
    ViewSonic's exclusive SonicExpert technology incorporates a ported speaker chamber and a more powerful amplifier to deliver higher volume and the absolute best-in-class sound.
  • Easy image adjustments
    Horizontal and vertical keystone correction and a corner adjustment feature eliminate crooked and distorted images for a perfectly proportioned picture every time.
  • Network control of up to 256 projectors
    All LightStream PJD6 projectors come equipped with Crestron RoomView Express, an easy-to-use network management system that lets administrators remotely monitor and control up to 256 LightStream projectors from a single PC.
  • Easy Remote and App use
    A programmable "MyButton" can be configured to launch the most commonly used functions. A single remote control can also control up to eight projectors in the same venue. A Free App (called 'vRemote') also allows users to control a projector via a mobile device.
ViewSonic LightStream PJD6352 - DLP projector - 3D
DLP projector
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Keypad
Europe
Microdisplay
DMD Chip
Brightness
3500 ANSI lumens
Contrast Ratio
22000:1 (dynamic)
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Bulb type
210 Watt
Bulb life cycle
Up to 4000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video, component video
Speakers
Speaker(s) - integrated
315 Watt
31.6 cm x 22.8 cm x 10.37 cm
2.23 kg
3-year warranty
DLP projector
3D Capable
Built-in Devices
Keypad
Ethernet
Europe
Projector
Microdisplay
DMD Chip
Brightness
3500 ANSI lumens
Contrast Ratio
22000:1 (dynamic)
Image Size
76.2 cm - 762 cm
Throw Ratio
1.51 - 1.97:1
Digital Zoom Factor
2x
Resolution
XGA - XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
Bulb type
210 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction, zoom, focus
OSD Languages
Czech, Indonesian, Thai, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Korean, Indic (Indian Languages)
6-segment colour wheel, Office Viewer, DynamicEco Mode, Presentation Timer, MHL compliance, sleep timer, SonicExpert, Quick On/Off, ViewSonic SuperColor, Movie Mode, elevation feet
Lens
Focus Type
Manual
Zoom Type
Manual
Zoom Factor
1.3x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-30 / +30
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video, MHL
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Speakers
1 x mixed channel
2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 2 x audio line-in - mini-phone 3.5 mm , 1 x audio line-out - mini-phone 3.5 mm , 1 x USB - mini-USB Type B , 1 x HDMI input - 19 pin HDMI Type A , 1 x network - RJ-45 , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A
Cable cover, wireless remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection, security bar, keypad lock
Security Slot Type
Kensington security slot
Power Source
AC
315 Watt
Power Consumption Stand by
0.5 Watt
Software Included
ViewSonic Wizard
31.6 cm
22.8 cm
10.37 cm
2.23 kg
Limited warranty - pick-up and return - 3 years , Limited warranty - lamp - 1 year / 1000 hours
10 - 90% (non-condensing)
Sound Emission
32 dB
27 dB
