The ViewSonic LightStream PJD5555LW price-performance projector features 3,100 lumens, native WXGA 1280 x 800 resolution, intuitive, user-friendly design and a sleek white color chassis. SuperColor 6-Segment Color Wheel maximizes color saturation and brightness for true-to-life image projection, while SonicExpert technology delivers improved sound quality. The PJD5555LW also features connectivity including two input ports, HDMI and VGA, and a RS232 control port. An energy-saving DynamicEco feature reduces power consumption by up to 70%, and extends the lamp life. With advanced audiovisual features, flexible connectivity options, and an affordable price, the PJD5555LW is ideal for use in education and small business environments.
3LCD projectors distance match
With a throw ratio ranging from 1.49 to 1.79, this projector is primed to replace typical 3LCD projectors (EPSON, NEC, Hitachi, Panasonic, Sony) without having to move or re-install existing ceiling mounts. Also equipped with a 1.2x optical zoom lens, this projector provides mounting flexibility with a wider throw distance range. -
Widescreen brilliance
With high resolution 16:10 WXGA (1280 x 800) display, this projector is the affordable solution for modern day widescreen devices. Whether connecting it to a widescreen notebook in the conference room, or watching 720P HD content in the classroom, distortion-free images with matching aspect ratio are guaranteed. It is also backward compatible with 4:3 content. -
HDMI for one-cable connectivity to HD devices
The best and easiest way to connect to most modern HD devices is through an HDMI (High Definition Media Interface) cable. HDMI carries both video and sound thus limiting the requirement to attach an additional audio cable. -
SuperColor
ViewSonic's exclusive SuperColor Technology offers a wider color range than conventional projectors for true-to-life color performance in any light. SuperColor 6-Segment Color Wheel maximizes brightness with the highest color saturation over others in the same class. -
SonicExpert clear, comfortable and louder sound
Following groundbreaking and exclusive speaker developments - transducer and chamber re-design - LightStream projectors deliver superior audio performance than competitor projectors. The compact yet powerful speakers sound stronger and enable sound to travel further, powerful enough to fill your meeting room with wall-to-wall sound. -
Bright images for any environment
Packed with 3,100 lumens the PJD5555Lw is guaranteed to produce bright images in any environment - even in rooms with high ambient light. The impressive 18,000:1 contrast ratio also ensures that dark and bright areas are more black and white and less gray in appearance. -
Easy-of-use pre-set color modes
Providing 5 pre-set color modes, users can choose the best one to suit their material. These 5 modes are: Brightest Mode for environments where extra-high brightness is required; Dynamic Mode for presentations with a lot of text; Standard Mode for matching PC or notebook color; ViewMatch Mode for general viewing; Movie Mode for watching movies with better saturation in a dark environments.
- ViewSonic LightStream PJD5555Lw - DLP projector - 3D - white
- DLP projector - 720p
- 3D Capable
- Yes (3D glasses sold separately)
- White
- Built-in Devices
- Speaker
- Localisation
- Europe
- Brightness
- 3100 ANSI lumens
- Contrast Ratio
- 18000:1 (dynamic)
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Colour Support
- 1.07 billion colours
- Bulb life cycle
- Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- Component video
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 265 Watt
- 36.2 cm x 23.1 cm x 10.9 cm
- 2.4 kg
- 3D Capable
- Built-in Devices
- Speaker
- Enclosure Colour
- White
- Localisation
- Europe
Projector
- Brightness
- 3100 ANSI lumens
- Contrast Ratio
- 18000:1 (dynamic)
- Image Size
- 76.2 cm - 762 cm
- Throw Ratio
- 1.49 - 1.79:1
- Digital Zoom Factor
- 2x
- Resolution
- WXGA - WXGA (1280 x 800)
- 16:10
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- OSD Languages
- Czech, Indonesian, Thai, Chinese (traditional), Chinese (simplified), Vietnamese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese, Korean, Indic (Indian Languages)
- DLP 3D Ready, Super Color, DynamicEco Mode, Auto Power Off, Presentation Timer, auto power on, sleep timer, My Button
Lens
- Zoom Type
- Manual
- Zoom Factor
- 1.1x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- Analogue video Signal
- Component video
- Video Interfaces
- VGA, HDMI
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 2 Watt
- Speakers
- 1 x mixed channel
- 1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x USB - mini-USB Type B , 1 x HDMI input - 19 pin HDMI Type A
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), password protection, security bar, keypad lock
- Power Source
- AC
- Voltage Required
- 265 Watt
- Power Consumption Stand by
- 0.5 Watt
- 36.2 cm
- 23.1 cm
- 10.9 cm
- 2.4 kg
- Sound Emission
- 32 dB
- Sound Emission (Economic Mode)
- 28 dB
