ViewSonic PJD5555LW 1200x800 3200 Lumens LED 3D Projector
Quicklinx: BDYVWS00 Mfr#: PJD5553LWS
The ViewSonic LightStream PJD5553Lws short throw projector can create 100" screens from only approximately 120cm from the wall. With a stylish white chassis it also features HDMI & 2x VGA connectivity and high resolution widescreen images. The color & sound performance are powered by an exclusive SuperColor 6-Segment Color Wheel and SonicExpert audio technology, whilst DynamicEco mode extends lamp life up to 10,000 hours.
  • Short throw for large sceens from small distances
    The short throw lens enables large images to be projected from short distances in small rooms (100" screen from approximately 100cm from the wall). This means there are no distracting shadows on the projected image, and no blinding lights in the eyes of presenters.
  • Widescreen brilliance
    With high resolution widescreen images (WXGA 1280 x 800), this projector is perfect for movies, gaming, sports and wide-format presentations. Distortion-free from widescreen material it is also compatible with other common display resolutions.
  • HDMI for one-cable connectivity to HD devices
    The best and easiest way to connect to most modern HD devices is through an HDMI (High Definition Media Interface) cable. HDMI carries both video and sound thus limiting the requirement to attach an additional audio cable.
  • Bright images for any environment
    Packed with 3,200 lumens the PJD5553Lws is guaranteed to produce bright images in any environment - even in rooms with high ambient light. The high 20,000:1 contrast ratio also ensures that dark and bright areas are more black and white and less gray in appearance.
  • SuperColor
    ViewSonic's exclusive SuperColor Technology offers a wider color range than conventional projectors for true-to-life color performance in any light. SuperColor 6-Segment Color Wheel maximizes brightness with the highest color saturation over others in the same class.
  • SonicExpert clear, comfortable and louder sound
    Following groundbreaking and exclusive speaker developments - transducer and chamber re-design - LightStream projectors deliver superior audio performance than competitor projectors. The compact yet powerful speakers sound stronger and enable sound to travel further, powerful enough to fill your meeting room with wall-to-wall sound.
  • Easy-of-use pre-set color modes
    Providing 5 pre-set color modes, users can choose the best one to suit their material: Brightest, Dynamic, Standard, ViewMatch or Movie.
  • 144Hz 3D compatible for exciting visual effects
    You'll have amazing 144Hz 3D capabilities at your disposal with this LightStream Projector. All that's required to unlock this stunning 3D are optional ViewSonic 3D active shutter glasses (PGD-350) and a 3D source
  • Hide unsightly cables
    An optional cable management hood connects onto the back of the projector to hide unsightly cable clutter and exposed ports.
ViewSonic LightStream PJD5553Lws - DLP projector - short-throw - 3D - white
DLP projector - 720p
3D Capable
Yes (3D glasses sold separately)
White
Built-in Devices
Speaker
Europe
Brightness
3000 ANSI lumens
Contrast Ratio
20000:1 (dynamic)
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Lens
Short-throw fixed lens
Bulb life cycle
Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
S-Video, composite video, component video
Speakers
Speaker(s) - integrated
265 Watt
31.6 cm x 22.8 cm x 10.37 cm
2.5 kg
3D Capable
Built-in Devices
Speaker
Enclosure Colour
White
Europe
Projector
Brightness
3000 ANSI lumens
Contrast Ratio
20000:1 (dynamic)
Image Size
76.2 cm - 762 cm
Throw Ratio
0.49:1
Digital Zoom Factor
2x
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
Max Sync Rate (V x H)
144 Hz
Bulb life cycle
Controls & Adjustments
Keystone correction
OSD Languages
Czech, Indonesian, Thai, Chinese (traditional), Chinese (simplified), Vietnamese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese, Korean, Indic (Indian Languages)
6-segment colour wheel, Super Color, DynamicEco Mode, Presentation Timer, sleep timer, SonicExpert
Lens
Zoom Type
Manual
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
2 Watt
Speakers
1 x mixed channel
2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x USB - mini-USB Type B , 1 x HDMI input - 19 pin HDMI Type A , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15)
Wireless remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection, security bar, keypad lock
Power Source
AC
265 Watt
Power Consumption Stand by
0.5 Watt
31.6 cm
22.8 cm
10.37 cm
2.5 kg
Sound Emission
32 dB
28 dB
