The ViewSonic LightStream PJD5550LWS price-performance short throw projector features 3,200 lumens, native WXGA 1280 x 800 resolution, user-friendly design, and a sleek white chassis. Exclusive SuperColor 6-Segment Color Wheel maximizes color saturation and brightness for true-to-life image projection, while SonicExpert technology delivers improved sound quality. A short throw lens with a 0.5 throw ratio offers large projection images for smaller rooms. The PJD5255L also features HDMI and VGA connectivity, and a RS232 control port. An energy-saving DynamicEco feature reduces power consumption by up to 70%, and extends the long lamp life. With advanced audiovisual features, flexible connectivity, and an affordable price, the PJD5550LWS is ideal for use in education and small business environments.
SuperColor: best in class color accuracy
ViewSonic's proprietary SuperColor technology offers a wider color range than conventional DLP projectors for true-to-life color performance in any light. SuperColor 6-segment color wheel maximizes brightness Increased by 15% or more with the highest color saturation over others in the same class. -
Widescreen brilliance
With native 1280 x 800 (WXGA) resolution, the wide-format projector offers a tremendous degree of flexibility and compatibility. Whether connecting it to a widescreen notebook in the conference room, or watching 720P HD content in the classroom, distortion-free images with matching aspect ratio are guaranteed. Besides, it is also compatible with other common display resolutions. -
Short throw lens for large projections in small places
The short throw lens enables large images to be projected from short distances in small rooms. This means there are no distracting shadows on the projected image, and no blinding lights in the eyes of presenters. -
3D Blu-ray ready HDMI
Equipped with the HDMI, this projector can display 3D images directly from 3D Blu-ray players - perfect for connecting to any HDMI-enabled devices such as PCs, laptops, tablets, and media players.
- ViewSonic LightStream PJD5550LWS - DLP projector - short-throw - 3D - white
- DLP projector - 720p
- 3D Capable
- Yes (3D glasses sold separately)
- White
- Built-in Devices
- Speaker
- Localisation
- Europe
- Brightness
- 3300 ANSI lumens
- Contrast Ratio
- 20000:1 (dynamic)
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Colour Support
- 1.07 billion colours
- Lens
- Short-throw fixed lens
- Bulb life cycle
- Up to 4000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- Component video
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 275 Watt
- 36.2 cm x 24.8 cm x 11.6 cm
- 2.5 kg
- 3D Capable
- Built-in Devices
- Speaker
- Enclosure Colour
- White
- Localisation
- Europe
Projector
- Brightness
- 3300 ANSI lumens
- Contrast Ratio
- 20000:1 (dynamic)
- Image Size
- 76.2 cm - 762 cm
- Throw Ratio
- 0.50:1
- Digital Zoom Factor
- 2x
- Resolution
- WXGA - WXGA (1280 x 800)
- 16:10
- Colour Support
- Max Sync Rate (V x H)
- 144 Hz
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- OSD Languages
- Czech, Indonesian, Thai, Chinese (traditional), Chinese (simplified), Vietnamese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese, Korean, Indic (Indian Languages)
- 6-segment colour wheel, Super Color, DynamicEco Mode, Presentation Timer, sleep timer, SonicExpert
Lens
- Zoom Type
- Manual
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- Analogue video Signal
- Component video
- Video Interfaces
- VGA, HDMI
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 2 Watt
- Speakers
- 1 x mixed channel
- 1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x USB - mini-USB Type B , 1 x HDMI input - 19 pin HDMI Type A
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), password protection, security bar, keypad lock
- Power Source
- AC
- Voltage Required
- 275 Watt
- Power Consumption Stand by
- 0.5 Watt
- 36.2 cm
- 24.8 cm
- 11.6 cm
- 2.5 kg
- Sound Emission
- 32 dB
- Sound Emission (Economic Mode)
- 28 dB
