ViewSonic's PJD5453s is perfect for use in limited room space. Boasting BrilliantColor technology, 3,000 lumens, and a 15,000:1 contrast ratio, the PJD5453s delivers clear, crisp images and vividly accurate colors to best meet the environment requirements of any presentation. This budget-friendly option features DynamicEco Technology allowing it to automatically adjust lamp brightness, extending the lamp life to 8000 hours. The HDMI connection and multiple video input options in the PJD5453s provide flexible connections to a variety of media devices while the integrated speaker saves the effort of connecting external speakers. The off-to-go mode, vertical keystone correction, and 120 Hz/3D ready functions allow the operation of this projector series to be simple and efficient, making presentations easier than ever.
Short throw projection
The PJD5453s adopts a cutting-edge short throw lens that requires 0.76 meters for a 72" image projection. The short throw facilitates a more comfortable presentation experience by eliminating distractions from shadows on the screen, as well as eyestrain and glare from the projector's blinding light. -
8000-hours high performance long-life light bulbs
The energy-saving mode on the PJD5453s automatically adjusts the brightness to optimize performance, extending the lamp life to up to 8000 hours and saving maintenance costs. -
DynamicEco technology makes excellent energy conservation
ViewSonic's proprietary DynamicEco technology will automatically adjust lamp brightness to prolong projector lamp life and conserve up to 70% power consumption. -
3D projection ready
The 3D DLP Link technology brings presentations to life by supporting an image update frequency of 120 Hz, allowing the projected images to be displayed with a 3D stereoscopic effect. -
Easy vertical keystone correction
When projectors are tilted, the projection image aspect ratio may display rectangular images in a trapezoidal shape, resulting in image distortion. The PJD5453s offers +40°/-40° keystone correction to fix image distortion issues easily and quickly. -
Ultra-low power consumption in standby mode
The PJD5453s consumes only 0.5 W in standby mode, saving ownership cost and practicing environmental friendliness. -
Off-to-go mode saves your time
The efficient off-to-go mode on the PJD5453s enables quick shutdown and turn-on, saving every second of your valuable time. The PJD5453s takes only 3 seconds to turn on and shuts down instantly, requiring zero power consumption to cool down the projector.
- ViewSonic PJD5453s - DLP projector - 3D - black
- DLP projector
- 3D Capable
- Black
- Microdisplay
- DMD Chip
- Brightness
- 3000 lumens
- Contrast Ratio
- 15000:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Bulb life cycle
- Up to 5000 hour(s) - normal mode , Up to 8000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video (SECAM, PAL, PAL-B/G, PAL-N, PAL-M, PAL-I, PAL 60, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - internal
- Power
- AC 120/230 V (50/60 Hz)
- 315 Watt
- 29.4 cm x 20.2 cm x 9.5 cm
- 3-year warranty
- DLP projector
- 3D Capable
- Enclosure Colour
- Black
Projector
- Microdisplay
- DMD Chip
- Brightness
- 3000 lumens
- Contrast Ratio
- 15000:1
- Throw Ratio
- 0.52:1
- Resolution
- XGA - XGA (1024 x 768)
- 4:3
- Max Sync Rate (V x H)
- 120 Hz x 100 kHz
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- OSD Languages
- Czech, Indonesian, Thai, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese, Korean, Indic (Indian Languages)
- 6-segment colour wheel, BrilliantColor, DLP 3D Ready, Short Throw Technology, DynamicEco Mode
Lens
- Keystone Correction Type
- Digital
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- SECAM, PAL, PAL-B/G, PAL-N, PAL-M, PAL-I, PAL 60, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC
- Analogue video Signal
- Video Interfaces
- VGA, composite video, S-Video
- Video Modes
Speakers
- Internal
- Sound Output Mode
- Stereo
- Output Power / Channel
- 2 Watt
- Speakers
- 2 x right / left channel
- 2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x USB - mini-USB Type B , 1 x audio line-out - mini-phone 3.5 mm , 2 x audio line-in - mini-phone 3.5 mm
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x VGA cable - 1.8 m
- Voltage Required
- 315 Watt
- Power Consumption Stand by
- 0.5 Watt
- Software Included
- ViewSonic Wizard
- 29.4 cm
- 20.2 cm
- 9.5 cm
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
