The ViewSonic LightStream PJD5353Ls short throw projector can create 100" screens from only approximately 120cm from the wall. With a stylish white chassis it also features HDMI & 2x VGA connectivity and high resolution 4:3 images. Color & sound performance are powered by an exclusive SuperColor 6-Segment Color Wheel and SonicExpert audio technology, whilst DynamicEco mode extends lamp life up to 10,000 hours.
Short throw for large sceens from small distances
The short throw lens enables large images to be projected from short distances in small rooms (100" screen from approximately 120cm from the wall). This means there are no distracting shadows on the projected image, and no blinding lights in the eyes of presenters. -
HDMI for one-cable connectivity to HD devices
The best and easiest way to connect to most modern HD devices is through an HDMI (High Definition Media Interface) cable. HDMI carries both video and sound thus limiting the requirement to attach an additional audio cable. -
Bright Images for any environment
The PJD5353Ls is guaranteed to produce bright images in any environment - even in rooms with high ambient light. The high 20,000:1 contrast ratio also ensures that dark and bright areas are more black and white and less gray in appearance. -
SuperColor
ViewSonic's exclusive SuperColor technology offers a wider color range than conventional projectors for true-to-life color performance in any light. SuperColor 6-Segment Color Wheel maximizes brightness with the highest color saturation over others in the same class. -
SonicExpert clear, comfortable and louder sound
Following groundbreaking and exclusive speaker developments - transducer and chamber re-design - LightStream projectors deliver superior audio performance than competitor projectors. The compact yet powerful speakers sound stronger and enable sound to travel further, powerful enough to fill your meeting room with wall-to-wall sound. -
144Hz 3D compatible for exciting visual effects
You'll have amazing 144Hz 3D capabilities at your disposal with this LightStream Projector. All that's required to unlock this stunning 3D are optional ViewSonic 3D active shutter glasses (PGD-350) and a 3D source -
Hide unsightly cables
An optional cable management hood connects onto the back of the projector to hide unsightly cable clutter and exposed ports.
- ViewSonic LightStream PJD5353Ls - DLP projector - short-throw - 3D - white
- DLP projector
- 3D Capable
- Yes (3D glasses sold separately)
- White
- Built-in Devices
- Speaker
- Localisation
- Europe
- Brightness
- 3000 ANSI lumens
- Contrast Ratio
- 20000:1 (dynamic)
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Colour Support
- 1.07 billion colours
- Lens
- Short-throw fixed lens
- Bulb life cycle
- Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- S-Video, composite video, component video
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 265 Watt
- 31.6 cm x 22.8 cm x 10.37 cm
- 2.5 kg
- DLP projector
- 3D Capable
- Built-in Devices
- Speaker
- Enclosure Colour
- White
- Localisation
- Europe
Projector
- Brightness
- 3000 ANSI lumens
- Contrast Ratio
- 20000:1 (dynamic)
- Image Size
- 76.2 cm - 762 cm
- Throw Ratio
- 0.61:1
- Digital Zoom Factor
- 2x
- Resolution
- XGA - XGA (1024 x 768)
- 4:3
- Colour Support
- Max Sync Rate (V x H)
- 144 Hz
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- OSD Languages
- Czech, Indonesian, Thai, Chinese (traditional), Chinese (simplified), Vietnamese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese, Korean, Indic (Indian Languages)
- 6-segment colour wheel, Super Color, DynamicEco Mode, Presentation Timer, sleep timer, SonicExpert
Lens
- Zoom Type
- Manual
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 2 Watt
- Speakers
- 1 x mixed channel
- 2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x USB - mini-USB Type B , 1 x HDMI input - 19 pin HDMI Type A , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15)
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), password protection, security bar, keypad lock
- Power Source
- AC
- Voltage Required
- 265 Watt
- Power Consumption Stand by
- 0.5 Watt
- 31.6 cm
- 22.8 cm
- 10.37 cm
- 2.5 kg
- Sound Emission
- 32 dB
- Sound Emission (Economic Mode)
- 27 dB
