Your basket is empty
ViewSonic PJD5353LS XGA 1024x768 3000 Lumens LED 3D Projector
Quicklinx: BDYTWS00 Mfr#: PJD5353LS
The ViewSonic LightStream PJD5353Ls short throw projector can create 100" screens from only approximately 120cm from the wall. With a stylish white chassis it also features HDMI & 2x VGA connectivity and high resolution 4:3 images. Color & sound performance are powered by an exclusive SuperColor 6-Segment Color Wheel and SonicExpert audio technology, whilst DynamicEco mode extends lamp life up to 10,000 hours.
ViewSonic LightStream PJD5353Ls - DLP projector - portable - 3D
DLP projector
3D Capable
Yes (3D glasses sold separately)
White
Built-in Devices
Speaker
Europe
Brightness
3000 ANSI lumens
Contrast Ratio
20000:1 (dynamic)
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Lens
Short-throw fixed lens
Bulb life cycle
Up to 5000 hour(s) / up to 10000 hour(s) (economic mode)
Video Input
S-Video, composite video, component video
Speakers
Speaker(s) - integrated
265 Watt
31.6 cm x 22.8 cm x 10.37 cm
2.5 kg
DLP projector
3D Capable
Built-in Devices
Speaker
Enclosure Colour
White
Europe
Projector
Brightness
3000 ANSI lumens
Contrast Ratio
20000:1 (dynamic)
Image Size
76.2 cm - 762 cm
Throw Ratio
0.61:1
Digital Zoom Factor
2x
Resolution
XGA - XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
Max Sync Rate (V x H)
144 Hz
Bulb life cycle
Controls & Adjustments
Keystone correction
OSD Languages
Czech, Indonesian, Thai, Chinese (traditional), Chinese (simplified), Vietnamese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese, Korean, Indic (Indian Languages)
6-segment colour wheel, Super Color, DynamicEco Mode, Presentation Timer, sleep timer, SonicExpert
Lens
Zoom Type
Manual
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
2 Watt
Speakers
1 x mixed channel
2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x USB - mini-USB Type B , 1 x HDMI input - 19 pin HDMI Type A , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15)
Wireless remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection, security bar, keypad lock
Power Source
AC
Nominal Voltage
265 Watt
Power Consumption Stand by
0.5 Watt
31.6 cm
22.8 cm
10.37 cm
2.5 kg
Sound Emission
32 dB
27 dB
