Product
Brand
ViewSonic PJD5255 XGA 3D 3300 Lumens Curved Projector
Best in Class Colour Accuracy!
Quicklinx: B6HSWS00 Mfr#: PJD5255
The brand new LightStream Projector PJD5255 integrates its elegant style and thoughtfully intuitive design, offering HDMI connectivity, high image and sound quality. With SuperColor™ and SonicExpert™ technology respectively delivering astonishing pictures and quality sound, the 3,200-lumen PJD5255 is equipped with native XGA resolution, a 15,000:1 contrast ratio with DynamicEco™, as well as extensive analog connectivity. DynamicEco™ further reduces power consumption by up to 70% and extends the lamp life by up to 10,000 hours.
Premium Curved Design With Intuitive Keypad
With its matte hairline finish and curved edges, this LightStream Projector stands out from the competition. A tactile keypad provides ease of use with raised and concave buttons, plus a central reference button. These assist in making set up easier in dark environments or if the projector is ceiling mounted.
SuperColor™ Best in Class Colour Accuracy
ViewSonic's exclusive SuperColor™ Technology delivers superior colour range than competitor projectors, ensuring that users enjoy more realistic and accurate colours. With an exclusive colour wheel design and dynamic lamp control capabilities, SuperColor™ Technology projects images with true-to-life colour performance in all scenarios, also reducing eye fatigue in bright and dark images.
SonicExpert™ Clear, Comfortable and Louder Sound
Following groundbreaking and exclusive speaker developments - transducer and chamber re-design - LightStream projectors deliver superior audio performance than competitor projectors. The compact yet powerful speakers sound stronger and enable sound to travel further, powerful enough to fill your meeting room with wall-to-wall sound.
HDMI for One-Cable Connectivity to HD Devices
The best and easiest way to connect to most modern devices is through an HDMI (High Definition Media Interface) cable. HDMI carries both video and sound thus limiting the requirement to attach an additional audio cable, as is often the case with other input options.
Bright Images for Any Environment
Packed with 3,200 lumens the PJD5255 is guaranteed to produce bright images in any environment - even in rooms with high ambient light. The high contrast ratio of 15,000:1 also ensures that dark and bright areas are more black and white and less grey in appearance.
Easy-of-Use Pre-Set Colour Modes
Providing 5 pre-set colour modes, users can choose the best one to suit their material. These 5 modes are: Brightest Mode for environments where extra-high brightness is required; Dynamic Mode for presentations with a lot of text; Standard Mode for matching PC or notebook colour; ViewMatch Mode for general viewing; Movie Mode for watching movies with better saturation in a dark environments.
Quickly Access Your Favourite Features With "My Button"
Finding a function through the on-screen menu can be time-consuming. The "My Button" button on the remote control is a programmable shortcut button that can be user-programmed to launch any desired function.
Auto Power On / Off
With 'Auto Power On' enabled, once a VGA cable is connected and signal detected, LightStream projectors will power on automatically with effortless start-up. When no signal is detected, the projector will automatically power off after a user-defined amount of time - saving electricity cost, reducing energy consumption and extending the life of the projector.
3D Compatible for Exciting Visual Effects
You'll have amazing 144Hz 3D capabilities at your disposal with this LightStream Projector. All that's required to unlock this stunning 3D are optional ViewSonic 3D active shutter glasses (PGD-350) and a 3D source. Unleash a vivid 3D experience with the ViewSonic LightStream projectors today.
ViewSonic DLP projector - 3D
DLP projector
3D Capable
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Speakers
Speaker(s)
AC 120/230 V
DLP projector
3D Capable
Projector
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Lens
Keystone Correction Direction
Vertical
Nominal Voltage
AC 120/230 V
