ViewSonic PJD5153 SVGA 3300 Lumens Projector
Quicklinx: B2GCWS00 Mfr#: PJD5153
The LightStream Projector PJD5153 is designed with elegant style and audiovisual performance. This projector makes a big statement with its elegant curves and light beam shape. Its thoughtful design, which includes a tactile keypad, instructional icons, and non-slip foot pads, also presents an intuitive and user-friendly interface. With SuperColor delivering astonishing pictures, users can experience a wider color range for true-to-life image projection. The LightStream Projector PJD5153 is also powered by SonicExpert technology; the resigned built-in speaker surpasses competing products in sound clarity and volume performance, as well as comfort. The LightStream Projector PJD5153 boasts a 3,200-lumen lamp with a 15,000:1 contrast ratio with DynamicEco for clearer and brighter images. From small to medium meeting rooms or classrooms, LightStream Projector PJD5153 delivers quality images in brightness and colors. Supporting 2 x VGA, Composite Video, S-Video, and 1 x VGA output, Mini USB and RS232, this projector has flexible connectivity with analog-based equipment, providing compatibility with conventional analog-based applications without adapters or converters. DynamicEco further reduces power consumption by up to 70% and extends the lamp life by up to 10,000 hours.
  • SuperColor provides color accuracy
    ViewSonic's proprietary SuperColor Technology offers a wider color range than conventional DLP projectors, ensuring that users enjoy more realistic and accurate colors. With an exclusive color wheel design and dynamic lamp control capabilities, SuperColor Technology projects images with reliable and true-to-life color performance, in both bright and dark environments, without sacrificing image quality.
  • Bright images for any environment less lighting limitations
    Packed with 3,200 lumens and a high contrast ratio, the PJD5153 is guaranteed to produce bright images in any environment - even in rooms with high ambient light.
  • Different view modes
    Providing 5 view modes for different scenarios, users can choose one fit mode at once for best view according to the projection environment. These 5 modes are: Brightest Mode for environments where extra-high brightness is required, Dynamic Mode for presentations under daylight environment and text content, Standard Mode for matching PC or NB color, ViewMatch Mode for general viewing, Movie Mode for watching movies with better saturation in a dark environment.
  • SonicExpert Clear, comfortable, and louder sound over same-clas
    Following a groundbreaking proprietary speaker transducer and chamber re-design, LightStream projectors deliver full-range sound 20Hz - 20KHz for presentations or off-the-clock home entertainment. The compact speakers take pride in quality sound with best-fit Sound Response Curve, and high efficiency of transferring electric power to sound power. The 2-watt speakers are powerful enough to fill you meeting room with wall-to-wall sound - an improvement over the speakers of competing products in the same class.
  • 1-to-8 projector control convenient and instant control
    Set-up up to 8 projectors in the same venue through a single remote control for effortless projector selection, configuration and operation during lessons or meetings.
  • DynamicEco technology up to 70% power savings
    With the DynamicEco button on the remote control, users can take command of presentations by dimming the screen brightness by 70%. DynamicEco mode is auto-activated whenever the projector is idle, the lamp's power consumption is significantly reduced with low noise for longer lamp life up to 10,000 hours - a great energy-saving design that lowers the total cost of ownership (TCO).
  • Smart Restart Instant reactivation during presentation
    With the DynamicEco button on the remote control, users can take command of presentations by dimming the screen brightness by 70%. DynamicEco mode is auto-activated whenever the projector is idle - allowing users to easily shift the audience's focus away from the presentation and back to the presenter when the projector is not in use. When idle, the projector will auto-activate DynamicEco mode as well. When DynamicEco mode is activated, the lamp's power consumption is significantly reduced with low noise for longer lamp life up to 10,000 hours - a great energy-saving design that lowers the total cost of ownership (TCO).
  • Auto Power On instant activation upon signal connection
    With Auto Power On enabled, once a VGA or HDMI cable is connected and signal detected, LightStream projectors will power on automatically with effortless start-up.
  • Auto power off
    Every time when no signal is detected, the projector will automatically power off after a user-defined amount of time. Every day forgetting to shut off projectors is a common occurrence, the sleep timer allows administrators to set up a timer to shut it the projector after a period of inactivity.
  • Quick power off leave without the wait
    Quick shut down in seconds because of smart electric and lamp designs are time-saving improvements that lead towards efficiency and energy savings.
  • 3D Ready / 120Hz Refresh Rate Powered by DLP Link Technology Ex
    With support for DLP Link technology, you'll have amazing 3D capabilities at your disposal. All that's required to unlock 3D capabilities on the ViewSonic LightStream 3D-ready projectors are ViewSonic 3D active shutter glasses, 3D content, and a 3D-enabled video card. Unleash a vivid 3D experience with the ViewSonic LightStream projectors today.
  • Presenter Timer Reminder for time management
    An embedded on-screen timer assists presenters to manage their times to avoid presentation over-runs that causes potential delays during scheduled sessions.
  • Patterns and templates world's first projector-embedded teaching
    Patterns are built-in templates such as tables, grids, worksheets, and charts on which teachers and students can draw when using an interactive projection. The results are fast illustrations with straight lines every time.
ViewSonic LightStream PJD5153 - DLP projector - 3D
DLP projector
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Speaker
Europe
Microdisplay
DMD Chip
Contrast Ratio
2400:1 / 15000:1 (dynamic)
Resolution
SVGA (800 x 600)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Bulb type
190 Watt
Bulb life cycle
Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video, component video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, PAL 60, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
265 Watt
31.6 cm x 22.8 cm x 10.37 cm
2.1 kg
DLP projector
3D Capable
Built-in Devices
Speaker
Europe
Projector
Microdisplay
DMD Chip
Brightness
3200 ANSI lumens
Brightness (Reduced)
2560 ANSI lumens
Contrast Ratio
Image Size
76.2 cm - 762 cm
Projection Distance
1 m - 8 m
Throw Ratio
1.86 - 2.04:1
Resolution
SVGA - SVGA (800 x 600) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
4:3
Colour Support
Max Sync Rate (V x H)
120 Hz x 102 kHz
Bulb type
190 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
DLP 3D Ready, ViewMatch, Super Color, Dynamic Mode, DynamicEco Mode, Auto Power Off, auto power on, SonicExpert
Lens
Focus Type
Manual
Zoom Type
Manual
Zoom Factor
2x
Keystone Correction Type
Digital
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, composite video, S-Video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
2 Watt
Speakers
1 x mixed channel
2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x audio line-in - mini-phone mono 3.5 mm , 1 x audio line-out - mini-phone mono 3.5 mm , 1 x USB - mini-USB Type B
Wireless remote control
1 x VGA cable - 1.8 m
Security Features
UL, TUV GS, C-Tick, cUL, ICES-003, SASO, TUV S, CB, CCC, EMC, DOC, PSB, FCC, RoHS, KCC, WEEE, REACH, UkrSEPRO, KC, ERP, EAC, SVHC, CoC
Power Source
AC
265 Watt
Power Consumption Stand by
0.5 Watt
Software Included
ViewSonic Wizard
31.6 cm
22.8 cm
10.37 cm
2.1 kg
10 - 90% (non-condensing)
Sound Emission
34 dB
29 dB
B2GC StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.82
B2GC StarTech.com HDMI to VGA Adapter Converter for Desktop PC / Laptop / Ultrabook - 1920x1080 In Stock £25.84
