Offering incredible color accuracy and stunning, razor-sharp images, the ViewSonic LightStream Pro7827HD is the ideal projector for home entertainment. Featuring Full HD 1080p resolution and ViewSonic's SuperColor RGBRGB technology, this projector delivers incredible detail and brilliantly smooth color gradients for true-to-life image projection. Designed with sRGB/Rec. 709 cinematic colors, ISF certified day and night modes, as well as a unique movie mode, the Pro7827HD delivers optimized color for a true cinema experience. SonicExpert, ViewSonic's proprietary sound enhancement technology, powers a 10W speaker to deliver incredibly clear and audible sound. The Pro7827HD also features a hidden HDMI/MHL connector with 5V USB power, whicokh is perfect for media streaming dongles. With a shorter throw ratio, vertical lens shift, 1.3x optical zoom, smart design, and extensive connectivity, the Pro7827HD provides flexible and quick set-up in any home.
Full HD 1080p for the finest picture quality
This projector features Full HD 1920x1080 (1080p) native resolution for the sharpest and clearest picture available, 144Hz 3D frame rate for smoother images and better 3D perception and DarkChip3 for deep blacks, finer pixels and exceptionally smooth motion. It is perfect for watching all types of high definition formats (1080p/1080i/720p) and content, including movies, videos, sports, games, and TV, without any distortion or scaling of the original video format. -
Cinema SuperColor RGBRGB color wheel for true-to-life color
The Cinema SuperColor RGBRGB Color Wheel adopts a special coating to filter segmental spectrums of RGB, to intensify Red, Blue, and Green colors. It fulfils sRGB and Rec. 709 standards, and features pure colors to increase visual performance, especially for Blu-ray DVDs. It also focuses on Hue and Saturation enhancement, highlighting breath-taking images like sunrises, sunsets, or blue skies with intense color gradients, while other projectors can only partially cover these complex color gradients. -
Superior performance with DarkChip3 from Oscar award winning TI DLP DMD display technology
DLP display technology combines accurate, long lasting color with high native contrast ratios. In particular, DLP utilizes "True Black", which improves projection accuracy, creating razor-sharp images for cinema, unlike other well-known technology projectors that use dark gray instead of "True Black" because of limited technology. DarkChip3 DMD is designed for high-definition video rendering to enhance contrast levels, creating extreme blacks and brilliant whites on the projected screen. -
ISF certified color calibration tools
ISF (Imaging Science Research Lab) Certified for customized color calibration, this projector provides the calibration tools to allow ISF-certified technicians to provide on-site tuning of Day and Night modes. The customized fine-tuned mechanism will become the default option to fit each user's scenario requirement in bright and dark environments. -
SonicExpert technology for clear, comfortable, and louder sound
Following a ground-breaking proprietary speaker transducer and chamber re-design, LightStream projectors deliver full-range sound 20Hz - 20KHz for presentations or off-the-clock home entertainment. The compact speaker takes pride in quality sound with best-fit Sound Response Curve, and high efficiency of transferring electric power to sound power. SonicMode The exclusive SonicMode sound settings deliver optimized audio performance for presentations, video clips and music. -
Easy image adjustment with complete keystone
Horizontal and vertical keystone correction, as well as a 4 corner adjustment feature eliminates crooked and distorted images for a perfectly proportioned picture every time. A 1.3x optical zoom lens provides mounting flexibility with a wider throw distance range while a 1.1 - 1.5 shorter throw ratio projects large images from short distances in small rooms. -
Smart design
The cable management hood connects onto the back of the projector to hide unsightly cable clutter and exposed ports. An easy-access top lamp door enables simple lamp maintenance and replacement. The tactile keypad is raised with concave buttons that assist in making projector set up easier in dark environments.
- ViewSonic LightStream Pro7827HD - DLP projector - zoom lens - 3D
- DLP projector - 1080p
- 3D Capable
- Yes (3D glasses sold separately)
- Built-in Devices
- Keypad
- Bundled Services
- 1 year Express Exchange Service
- Localisation
- Americas
- Brightness
- 2200 ANSI lumens
- Contrast Ratio
- 22000:1 (dynamic)
- Resolution
- Full HD (1920 x 1080)
- Native Aspect Ratio
- 16:9
- Colour Support
- 1.07 billion colours (30-bit)
- Lens
- Zoom lens
- Lens Shift Direction
- Vertical
- Bulb type
- 240 Watt
- Bulb life cycle
- Up to 3500 hours - normal mode , Up to 6500 hours - economic mode
- Video Input
- RGB, S-Video, composite video
- Video Modes
- 1080p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 350 Watt
- 31.6 cm x 22.8 cm x 10.37 cm
- 2.6 kg
- 3-year warranty
- 3D Capable
- Built-in Devices
- Keypad
- Bundled Services
- Localisation
- Americas
Projector
- Brightness
- 2200 ANSI lumens
- Contrast Ratio
- 22000:1 (dynamic)
- Image Size
- 76 cm - 762 cm
- Projection Distance
- 1.29 m - 14.28 m
- Throw Ratio
- 1.1 - 1.5:1
- Resolution
- Full HD - Full HD (1920 x 1080) (native) / 1920 x 1080 (resized)
- 16:9
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 100 kHz
- Bulb type
- 240 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction, zoom, focus, lens shift dial (vertical)
- Rec. 709 Mode, MHL compliance, SonicExpert, ISF (Imaging Science Foundation), PortAll, ViewSonic SuperColor TruCinema, ISF Night/Day
Lens
- Zoom lens
- Focus Type
- Manual
- Zoom Type
- Manual
- Zoom Factor
- 1.3x
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -30 / +30
- Vertical
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video, MHL
- Video Modes
- 1080p
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 10 Watt
- Speakers
- 1 x mixed channel
- 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 2 x audio line-in - mini-phone 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB - mini-USB Type B , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x USB - 4 pin USB Type A , 1 x HDMI input - 19 pin HDMI Type A
- Included Accessories
- Cable cover, wireless remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security Slot Type
- Kensington security slot
- C-Tick, NOM, TUV S, CB, CCC, FCC, RoHS, WEEE, cTUVus, REACH, ERP, CECP, EAC, SVHC
- Power Source
- AC
- Voltage Required
- 350 Watt
- Power Consumption Stand by
- 0.5 Watt
- Software Included
- ViewSonic Wizard
- 31.6 cm
- 22.8 cm
- 10.37 cm
- 2.6 kg
- Shipping Width
- 41 cm
- Shipping Depth
- 45 cm
- Shipping Height
- 22.5 cm
- Shipping Weight
- 5.3 kg
- Limited warranty - parts and labour - 3 years , Limited warranty - lamp - 1 year
- 0 °C
- 40 °C
- 0 - 90% (non-condensing)
- Sound Emission
- 34 dB
- Sound Emission (Economic Mode)
- 31 dB
