The ViewSonic EP5012-L is a 50" all-in-one free-standing digital ePoster kiosk with a sleek, slim design. It delivers high-impact messaging in a number of venues including shopping malls, retail stores, office complexes and school buildings. Great for grabbing attention in busy, high-traffic areas, the EP5012-L comes with a scratch-proof tempered glass faceplate for added durability. Featuring Full HD 1080p resolution, 176°/176° wide-angle viewing, 450-nit brightness, 5,000:1 contrast ratio, and dual 6W stereo speakers, the EP5012-L delivers customized multimedia messaging with vivid clarity. Photo and video files can be played back using the integrated media player and 8GB of internal memory, or directly from a USB hard drive. The bundled ePoster Manager Express Plus software make it easy to load and schedule customized multimedia content. Flexible HDMI, D-sub, USB (x2), and LAN connectivity also allow for additional content loading options from a PC or networkable media player. The EP5012-L also features an Embedded media player platform, enabling the implementation of customized messaging applications. Simple auto on/off scheduling via an on-screen display, as well as a security lock design, making this a reliable, and easy-to-maintain digital signage solution.
- ViewSonic 50" LED-backlit LCD flat panel display
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Size
- 50"
- Targeting
- Commercial use
- Resolution
- 1920 x 1080
- Display Format
- 1080p (FullHD)
- Video Interface
- HDMI
- HDCP Compatible
- LCD Backlight Technology
- WLED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- USB Port
- Yes , 2 port(s)
- Remote Control
- Remote control
- Power
- ( 50/60 Hz )
- Product Type
- Diagonal Size
- 50"
- Targeting
- Commercial use
- TV Tuner
- No tuner
- Video Interface
- HDMI
- HDCP Compatible
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p (FullHD)
- 16:9
- WLED backlight
Stands & Mounts
- Stand
- Included
- Flat Panel Mount Interface
- 75 x 75 mm
Media Player
- USB Port
- Yes , 2 port(s)
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Power Device
- Power supply
- Nominal Voltage
- ( 50/60 Hz )
