ViewSonic's EP3203r is a 32" LED ePoster that delivers brilliant and crystal clear image quality from a large, sleek, and slim profile. The premium design and slim profile allows it to be the perfect wall mount for informational and promotional applications in any setting, while the USB ports offer quick access to a wide range of formats for convenient content management.
- ViewSonic EP3203r 32" Class (31.5" viewable) LED-backlit LCD display - HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 32"
- Diagonal Size
- 31.5"
- Commercial Use
- Yes - digital signage
- Black
- Resolution
- 1366 x 768
- Display Format
- 720p
- Video Interface
- Composite, HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- VGA (HD-15)
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- USB
- 2 ports
- Included Accessories
- Remote control
- Voltage
- AC 120/230 V (50 - 60 Hz)
- 80.96 cm x 4 cm x 49.96 cm
- 15 kg
- Product Type
- Diagonal Class
- 32"
- Diagonal Size
- 31.5"
- Commercial Use
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- Composite, HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- VGA (HD-15)
- Protection
- Tempered glass protection
- 80.96 cm
- 4 cm
- 49.96 cm
- 15 kg
- Enclosure Colour
- Black
Display
- Resolution
- 1366 x 768
- Display Format
- 720p
- 16:9
- LED backlight
- Coating
- Anti-glare, 3H Hard
- Image Contrast Ratio
- 4000:1
- Brightness
- 320 cd/m²
- Viewing Angle
- 89 degrees
- Viewing Angle (Vertical)
- 89 degrees
Media Player
- Supported Video Formats
- MPEG-1, MPEG-2, MPEG-4, Xvid, H.264
- Supported Pictures Formats
- JPG
- USB Port
- USB Ports Qty
- 2
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 10 Watt
- Speakers
- 2 x speaker - 5 Watt
- Connector Type
- 2 x USB 2.0 , HDMI , VGA input , Composite video input , LAN
- Power Device
- Power supply
- Input Voltage
- 0 °C
- 50 °C
- 20 - 90% (non-condensing)
