ViewSonic EP1031R 10.1" 800x480 4GB Memory Touch Eposter
Quicklinx: C4VMWS00 Mfr#: EP1031R
The ViewSonic EP1031r is a 10.1" wall-mounted multimedia all-in-one electronic mini billboard. It delivers eye-catching commercial messaging at retail POS, hotel lobbies and front desks, conference and exhibition venues, and other high-visibility locations. The EP1031r features wireless b/g/n network and LAN connectivity for easy loading of content, and supports Power over Ethernet (PoE) for convenient one-wire installation. The EP1031r effectively delivers customized messaging to target audiences. Its built-in media player, internal storage, and integrated speakers enable the playback of video clips, as well as photos and music, from a USB hard drive or SD/SDHC memory card. With VESA-mount compliance, and W3C and SMIL compatibility, the EP1031r provides versatile options for creative brand messaging.
  • Perfect size for up-close, high-impact messaging
    ViewSonic's EP1031r all-in-one electronic mini billboard has a 10.1" display area with 800 x 480 resolution. With its compact design, the EP1031r can be deployed anywhere, including retail shelf edges, hotel front desks, in meeting rooms, or on classroom doors. The EP1031r features 300-nit brightness and a 500:1 contrast ratio to deliver high-impact, quality messaging that will attract the attention of passersby.
  • Advanced motion sensor and 6 programmable touch keys
    Equipped with an advanced motion sensor, the EP1031r can display customized content whenever movements of nearby people are detected. And with 6 highly visible and easy-to-use programmable touch keys, users can directly interact with brand offerings and retail messaging.
  • Convenient one-wire installation via Power over Ethernet
    The EP1031r utilizes state-of-the-art Power over Ethernet (PoE) technology for one-wire installation. This allows you to easily power and connect your displays with just a single cable. PoE also allows you to create multi-display digital signage installations, while reducing installation costs.
  • Easy loading of content through wireless/RJ45 Ethernet
    The EP1031r integrates wireless 802.11 b/g/n network and RJ45 Ethernet connectivity, providing a convenient and efficient way to load content from a PC or laptop connection. Wireless/LAN connectivity can also be used to remotely load content to multiple displays.
  • USB multimedia player for scheduled playback of videos, photos and music
    With the handy PC-less USB playback feature, photos, music and 1080p video can be immediately displayed on-screen from a USB drive. A user-friendly on-screen scheduling interface also lets you select time, date, repeat and shuffle settings, or choose specific content to play from the attached USB source. It's easy and efficient.
  • Built-in speakers that really speak to your audience
    Integrated with a pair of stereo 2 W speakers, the EP1031r combines eye-catching multimedia content with high-quality sound effects - creating an incredible audio-visual impression on your target audience.
ViewSonic EP1031r 10.1" LED-backlit LCD display - for interactive communication
LED-backlit LCD flat panel display
Diagonal Class
10.1"
Commercial Use
Yes - interactive
Resolution
800 x 480
Video Interface
HDMI
HDMI Ports Qty
1 ports
Wi-Fi, LAN
LCD Backlight Technology
LED backlight
TV Tuner
No tuner
Speaker System
2 speakers
Supported Memory Cards
SD Memory Card, SDHC Memory Card
USB
2 ports
Signage Manager Express software
Voltage
12 Watt
Power Consumption Stand by
0.5 Watt
27.8 cm x 4 cm x 18.6 cm
2.1 kg
12 Watt
Diagonal Class
10.1"
Commercial Use
Yes - interactive
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Motion sensor
Video Interface
HDMI
HDMI Ports Qty
1 ports
Dimensions
Without stand
27.8 cm
4 cm
18.6 cm
2.1 kg
Enclosure Colour
Display
Resolution
800 x 480
LED backlight
Coating
Anti-glare
Image Contrast Ratio
500:1
Brightness
300 cd/m²
Viewing Angle
170 degrees
Viewing Angle (Vertical)
160 degrees
Response Time
30 ms
Backlight Life
50,000 hour(s)
Security lock slot (cable lock sold separately), Synchronized Multimedia Integration Language (SMIL)
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Flat Panel Mount Interface
75 x 75 mm
Media Player
Supported Video Formats
MPEG-1, MPEG-2, MPEG-4, WMV
Supported Audio Formats
MP3
Supported Pictures Formats
JPG, PNG
USB Port
USB Ports Qty
2
Audio System
Speaker System
2 speakers
Output Power / Total
4 Watt
Speakers
2 x speaker - 2 Watt
Network & Internet Multimedia
Wi-Fi, LAN
LAN Protocol
Ethernet
Wi-Fi Protocol
802.11b, 802.11g, 802.11n
Connector Type
2 x USB 2.0 , HDMI , Audio line-out , LAN , USB 2.0
Network cable , Mini-phone 3.5 mm to 2 x RCA adapter
FCC
Power adapter
Input Voltage
0.5 Watt
5 - 85% (non-condensing)
