The ViewSonic CDP5560-L is a 55" commercial LED display designed for use 24 hours a day, 7 days a week. The CDP5560-L is ideal for sharing public information in indoor areas such as high-traffic transportation settings, as well as in education, hospitality, and commercial venues. Featuring a slim narrow bezel design, Full HD 1080p resolution, 450-nit high brightness, SuperClear image enhance technology with wide viewing angles, as well as dual 10 W stereo speakers, the CDP5560-L delivers sharp, vivid images with incredible sound for superior multimedia messaging performance. The CDP5560-L can display multimedia content in either landscape or portrait orientations for flexible installation. Versatile connectivity options include HDMI, DisplayPort, DVI, D-sub, YPbPr, and CVBS inputs for easy installation and control of a variety of high-definition devices. Equipped with DVI-out, the CDP5560-L supports up to a 5 x 5 daisy chain installation. In addition, integrated RS232 input and output, with IR pass-through and a content scheduling function make the CDP5560-L an easy-to-manage solution for 24/7 use.
- ViewSonic CDP5560-L 55" LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 55"
- Commercial Use
- Yes - digital signage
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Input Video Formats
- 480p, 720p, 1080i, 1080p, 480i
- Video Interface
- Component, HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- Included Accessories
- Remote control
- Voltage
- AC 120/230 V (50/60 Hz)
- 245 Watt
- Dimensions (WxDxH) - without stand
- 124.7 cm x 7 cm x 71.78 cm
- 30.6 kg
- Environmental Standards
- ENERGY STAR Qualified
- Product Type
- 245 Watt
- Diagonal Class
- 55"
- Commercial Use
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- Component, HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- HDCP Compatible
- Design
- Narrow Bezel Concept
- Dimensions
- Without stand
- 124.7 cm
- 7 cm
- 71.78 cm
- 30.6 kg
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight
- Coating
- 3H Hard
- Image Contrast Ratio
- 1300:1
- Brightness
- 450 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 12 ms
- Backlight Life
- 50,000 hour(s)
- 5x5 Daisy-Chain support
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 400 x 400 mm
Video Features
Remote Control
- Remote control
- Remote Control Pass Through
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
- Connector Type
- LAN , Serial input , Serial output , HDMI input , DisplayPort input , DVI-D input , DVI-D output , VGA input , Headphones , Component video input , Audio line-in , Audio line-out , Speakers input , Speakers output , SPDIF output , IR Blaster
- Cables Included
- VGA cable
- UL, C-Tick, cUL, ICES-003, CB, FCC, WEEE
Sustainability Information
- ENERGY STAR Certified
- Power Device
- Power supply
- Input Voltage
- Width (Shipping)
- 147.6 cm
- Depth (Shipping)
- 40 cm
- Height (Shipping)
- 97.8 cm
- Weight (Shipping)
- 36.1 kg
- 0 °C
- 40 °C
- 20 - 80% (non-condensing)
