ViewSonic CDP5560-L 55" 1920x1080 12ms VGA DVI HDMI DisplayPort LED Large Format Display
Quicklinx: 9M0KWS00 Mfr#: CDP5560-L
  • 1080p
The ViewSonic CDP5560-L is a 55" commercial LED display designed for use 24 hours a day, 7 days a week. The CDP5560-L is ideal for sharing public information in indoor areas such as high-traffic transportation settings, as well as in education, hospitality, and commercial venues. Featuring a slim narrow bezel design, Full HD 1080p resolution, 450-nit high brightness, SuperClear image enhance technology with wide viewing angles, as well as dual 10 W stereo speakers, the CDP5560-L delivers sharp, vivid images with incredible sound for superior multimedia messaging performance. The CDP5560-L can display multimedia content in either landscape or portrait orientations for flexible installation. Versatile connectivity options include HDMI, DisplayPort, DVI, D-sub, YPbPr, and CVBS inputs for easy installation and control of a variety of high-definition devices. Equipped with DVI-out, the CDP5560-L supports up to a 5 x 5 daisy chain installation. In addition, integrated RS232 input and output, with IR pass-through and a content scheduling function make the CDP5560-L an easy-to-manage solution for 24/7 use.
ViewSonic CDP5560-L 55" LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
55"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
Input Video Formats
480p, 720p, 1080i, 1080p, 480i
Video Interface
Component, HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote control
Voltage
245 Watt
124.7 cm x 7 cm x 71.78 cm
30.6 kg
Environmental Standards
ENERGY STAR Qualified
245 Watt
Diagonal Class
55"
Commercial Use
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
Component, HDMI
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
Design
Narrow Bezel Concept
Dimensions
Without stand
124.7 cm
7 cm
71.78 cm
30.6 kg
Display
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
LED backlight
Coating
3H Hard
Image Contrast Ratio
1300:1
Brightness
450 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
12 ms
Backlight Life
50,000 hour(s)
5x5 Daisy-Chain support
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
Video Features
Input Video Formats
Remote Control
Remote control
Remote Control Pass Through
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - 10 Watt
Connector Type
LAN , Serial input , Serial output , HDMI input , DisplayPort input , DVI-D input , DVI-D output , VGA input , Headphones , Component video input , Audio line-in , Audio line-out , Speakers input , Speakers output , SPDIF output , IR Blaster
VGA cable
UL, C-Tick, cUL, ICES-003, CB, FCC, WEEE
Sustainability Information
ENERGY STAR Certified
Power supply
Input Voltage
Width (Shipping)
147.6 cm
Depth (Shipping)
40 cm
Height (Shipping)
97.8 cm
Weight (Shipping)
36.1 kg
20 - 80% (non-condensing)
