Product
ViewSonic CDP4260-TL 42" 1920x1080 HDMI DP DVI LED Large Format Displa
Quicklinx: C4VLWS00 Mfr#: CDP4260-TL
TV Tuner Presence: No
Video Interface: Component, HDMI
  • 1080p (Full HD)
£2,531.84 ex VAT
£3,038.20 inc VAT
The ViewSonic CDP4260-TL is a 42" commercial LED display designed for use 24 hours a day, 7 days a week. Equipped with 6-point multi-touch functionality, the CDP4260-TL is ideal for providing interactive information in indoor areas such as high-traffic transportation settings, as well as in education, hospitality, and commercial venues. Featuring a slim 19.5mm narrow bezel design, Full HD 1080p resolution, 450-nit high brightness, SuperClear image enhance technology with wide viewing angles, as well as dual 10W stereo speakers, the CDP4260-TL delivers sharp, vivid images with incredible sound for superior multimedia messaging performance. Versatile connectivity options include HDMI, DisplayPort, DVI, D-Sub, YPbPr, and CVBS inputs for easy installation and control of a variety of high-definition devices. A built in OPS slot provides easy connectivity to an integrated PC as well. The CDP4260-TL also supports up to a 5x5 daisy chain installation. In addition, integrated RS232 input and output, with IR pass-through and a content scheduling function, make the CDP4260-TL an easy to-manage solution for 24/7 use.
  • Interactive on-demand messaging
    The CDP5560-TL delivers on-demand interactive messaging with 6-point multi-touch capability. This display is ideal for providing interactive information in indoor areas such as high-traffic transportation settings, as well as in education, hospitality, and commercial venues.
  • OPS Slot compatibility
    Equipped with Intel's Open Pluggable Specification (OPS), the CDP4260-TL provides for cable-free integration and easy installation in any environment. In addition, the CDP5560-TL can easily connect to an integrated media player to bring a multimedia experience to your customers.
  • 24/7 continuous operation, 50,000-hour lifespan
    Featuring a lifespan of up to 50,000 hours, the professional-grade CDP4260-TL commercial display is designed for reliable, continuous 24/7 use. The CDP4260-TL also includes heat monitoring protection and a screen saver feature for added reliability and durability.
  • Efficient, user-friendly content scheduling & settings
    The ViewSonic CDP4260-TL commercial display provides an efficient, user-friendly scheduling interface via the on-screen display (OSD). Display setup features include time and date scheduling, repeat and shuffle settings, as well as content source settings for various inputs. The CDP4260-TL also features an internal clock with 7-day scheduler, as well as PIP/POP (picture in picture) functionality.
  • Energy-saving LED backlight
    CDP4260-TL utilizes an energy-saving LED backlight and consumes 35% less power than conventional CCFL backlight displays. This provides for a lower overall cost of ownership, along with a higher ROI, making this display a great long-term investment.
  • Full HD and 450 nits for superior true-color performance
    ViewSonic's CDP4260-TL displays content in Full HD 1920x1080 resolution with 450-nit high brightness to deliver superior pixel-by-pixel true-color performance. At this resolution and brightness, high-definition multimedia messaging can be seen crystal-clear with a more realistic viewing experience.
  • 5x5 daisy-chain support
    With integrated DVI output, the CDP4260-TL supports up to a 5x5 daisy-chain setup for multi-display installations. As only one of the displays needs to be connected to an image / content source, installation and maintenance costs are reduced. In addition, 1080p signal transmission is supported in daisy-chain configurations.
  • RS232 in / out with IR pass-through for easy management
    RS232 input and output connectivity, along with IR pass-through functionality, provides for the easy and efficient management of multiple-display configurations from a single remote control. By using the RS232 output, daisy-chained configurations can be managed via a primary CDP4260-TL display.
  • Versatile inputs and one-time configuration settings
    With a versatile selection of inputs, including HDMI, DVI, DisplayPort, CVBS, YPbPr (YCbCr) and VGA, the CDP4260-TL commercial display enables you to easily connect and use a variety of digital equipment. Best of all, the one-time display installation and setup feature means your preferred source settings are never lost.
  • Portrait or landscape mountable
    The CDP4260-TL can be VESA-mounted in either portrait or landscape orientation for display flexibility in a variety of settings.
  • Dual stereo speakers for crystal-clear sound
    With a pair of integrated 10W speakers, the CDP4260-TL combines eye-catching multimedia content with high-quality sound effects - creating a lasting audio-visual impression on your target audience or demographic.
  • LAN control for remote network management
    The CDP4260-TL has an integrated RJ45 connection that allows you to remotely set up and manage display content from a PC or laptop. You can remotely turn the display on or off, or adjust the volume and other settings, via a user-friendly on-screen interface.
ViewSonic CDP4260-TL 42" LED display
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
42"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
480p, 720p, 1080i, 1080p, 480i
Video Interface
Component, HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote Control
Standard remote
Voltage
250 Watt
97.62 cm x 7.98 cm x 56.95 cm
24.8 kg
Environmental Standards
ENERGY STAR Qualified
3 years warranty
250 Watt
Diagonal Class
42"
Commercial Use
Combined with
Touchscreen
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
Component, HDMI
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
Design
Narrow Bezel Concept
Dimensions
Without stand
97.62 cm
7.98 cm
56.95 cm
24.8 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Coating
Anti-glare
Image Contrast Ratio
1300:1
Brightness
450 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Touchpoints Qty
6
Response Time
12 ms
Backlight Life
50,000 hour(s)
Colour Temperature Control
Certified for 24/7 Continuous Operation, 5x5 Daisy-Chain support
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
200 x 200 mm, 400 x 200 mm
Video Features
Input Video Formats
Remote Control
Standard remote
Audio System
Audio Controls
Balance, bass, treble
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Connector Type
Network , Serial input , Serial output , HDMI input , DisplayPort input , DVI-D input , DVI-D output , VGA input , Audio line-in , Component video input , Audio line-in , Audio line-out , USB , Speakers output
VGA cable , Serial cable
UL, ISO 9001, cUL, ISO 14001, FCC, WEEE, TUV Nord
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Limited warranty - parts and labour - 3 years , Limited warranty - backlight - 3 years
Width (Shipping)
115.5 cm
Depth (Shipping)
24.2 cm
Height (Shipping)
76.8 cm
Weight (Shipping)
30.6 kg
20 - 80% (non-condensing)
Video Interface: HDMI
Brand: ViewSonic
Price Range Ex VAT: 1500+
