Product
ViewSonic CDE8452T 84" 3840x2160 HDMI USB Touch Display
Quicklinx: C4VRWS00 Mfr#: CDE8452T
TV Tuner Presence: No
Video Interface: Component, Composite, HDMI
£6,024.35 ex VAT
£7,229.22 inc VAT
The ViewSonic CDE8452T is a stunning 84" 4K Ultra HD interactive touch display. It is ideal for higher education and corporate meeting applications, as well as for scientific, GIS, and wayfinding applications. The touch-enabled display allows up to ten users to simultaneously write or draw on the display's surface using their fingers or styluses. The large-format LED screen and Ultra HD resolution ensures the perfection in color, clarity, and image detail. Equipped with a tempered glass overlay, anti-glare treatment, and rounded corners, the CDE8452T is designed for heavy usage in high-traffic areas. The ViewSonic CDE8452T Ultra HD interactive touch display is the perfect solution where great imaging and touch interactive performance are needed.
  • 4K Ultra HD for perfect image quality
    Ultra HD resolution delivers four times the resolution of regular HD. With four times the resolution, the CDE8452T displays images with four times more detail, depth, and clarity. Even when interacting up close with the huge 84" touch screen, the images remain vivid and sharp without any noticeable pixilation. With 4K Ultra HD resolution, the CDE8452T delivers a breathtaking viewing experience with immersive images that are vibrant, clear, and as large as life.
  • Advanced 10-point touch-enabled capability for group interaction
    With 10-point simultaneous touch technology, the CDE8452T encourages group interaction. Up to ten users can simultaneously write or draw on the display's surface using styluses or their fingers - or both at the same time. And its great touch report rate provides a smoother user touch experience for both educational and corporate applications.
  • Protective rounded-corner design
    A rounded-corner design provides a safer learning environment for active students by helping to prevent injuries in the classroom.
  • Tough anti-scratch, anti-glare glass faceplate
    The ViewSonic CDE8452T features 7H scratch-resistant surface hardness that ensures durability, as well as a consistent, high-quality touch experience. In addition, an anti-glare film improves screen visibility in bright environments.
  • Energy-saving LED backlight
    The ViewSonic CDE8452T features an energy-saving LED backlight with a great lifespan, and more than a decade of durability. This lowers power consumption and the cost of ownership, while producing a high ROI, making this product a great long-term investment.
  • Versatile input selection for flexible connectivity
    With a versatile selection of inputs, the CDE8452T enables you to easily connect and use a variety of digital equipment. An HDMI input connects to high-definition content sources, while USB and VGA ports deliver additional connectivity opportunities.
ViewSonic CDE8452T 84" LED display
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
84"
Commercial Use
Yes - interactive communication
Country Kits
United Kingdom, Europe
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Video Interface
Component, composite, HDMI
HDMI Ports Qty
4 ports
PC Interface
VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
USB
4 ports
Remote Control
Standard remote
Voltage
500 Watt
197.8 cm x 9.5 cm x 118.7 cm
107 kg
500 Watt
Diagonal Class
84"
Commercial Use
Combined with
Touchscreen
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI Ports Qty
4 ports
PC Interface
VGA (HD-15)
HDCP Compatible
Protection
Anti-scratch display
197.8 cm
9.5 cm
118.7 cm
107 kg
Country Kits
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
LED backlight
Coating
Anti-glare, 7H Hard
Image Contrast Ratio
1600:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Touchpoints Qty
10
Response Time
8 ms
Backlight Life
50,000 hour(s)
Infrared multitouch technology
Stands & Mounts
Flat Panel Mount Interface
600 x 600 mm
Media Player
USB Port
USB Ports Qty
4
Operating System
Android OS 4.2
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
30 Watt
Bass & treble control, auto volume adjustment, balance control
Speakers
2 x main channel speaker - built-in - 15 Watt
Connector Type
3 x USB 2.0 , USB 3.0 , USB , 4 x HDMI input , 3 x VGA input , 3 x audio line-in , Composite video input , VGA output , Serial
3 styluses, ViewSonic Wizard software CD
VGA cable , USB cable , Audio cable
CCC, FCC
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Width (Shipping)
217 cm
Depth (Shipping)
32 cm
Height (Shipping)
137 cm
Weight (Shipping)
135 kg
20 - 80% (non-condensing)
Video Interface: Composite
Video Interface: HDMI
Brand: ViewSonic
Price Range Ex VAT: 1500+
