The ViewSonic CDE7060T 70’’(69.5’’ viewable) Full HD interactive LED display solution is perfect for business and education. This 10-point touch-enabled display, paired with pre-installed annotation software, allows multiple users to simultaneously write or draw on the display’s hardness surface using fingers or stylus. A Full HD screen guarantees crisp and vivid image quality, while 350-nit brightness and wide viewing angles provide better visual performance in well-lit rooms. With built-in dual core processor and 8GB internal storage, as well as integrated versatile connectivity including HDMI, VGA, YPbPr, RS232, RJ45 and USB ports, this display provides powerful computing for annotation and multimedia playback without the need for a PCThis Energy Star certified display delivers optional slot-in PC (NMP710) capability, offering Windows®8 Professional (64 Bit) OS and ViewBoard annotation software for more computing-intensive interactive applications. The CDE7060T is VESA mountable (wall mount kit WMK-047 included for Europe region) or choose the optional trolley cart for flexible installation for classrooms and corporate meeting rooms.
- ViewSonic 70" LED display
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Size
- 70"
- Commercial Use
- Resolution
- 1920 x 1080
- Display Format
- 1080p (FullHD)
- Video Interface
- HDMI
- Connectivity
- LAN
- PC Interface
- VGA (HD-15)
- HDCP Compatible
- LCD Backlight Technology
- LED backlight
- Speaker System
- 2 speakers
- USB Port
- Remote Control
- Remote control
- Power
- AC 100/240 V ( 50/60 Hz )
- Product Type
- Diagonal Size
- 70"
- Commercial Use
- Video Interface
- HDMI
- PC Interface
- VGA (HD-15)
- HDCP Compatible
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p (FullHD)
- LED backlight
Media Player
- USB Port
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
Network & Internet Multimedia
- Connectivity
- LAN
- Power Device
- Power supply
- Nominal Voltage
