Product
ViewSonic CDE7060T 70" 1920x1080 6ms VGA DVI HDMI DP LED LFD
Quicklinx: BHCMWS00 Mfr#: CDE7060T
  • 1080p (Full HD)
The ViewSonic CDE7060T 70’’(69.5’’ viewable) Full HD interactive LED display solution is perfect for business and education. This 10-point touch-enabled display, paired with pre-installed annotation software, allows multiple users to simultaneously write or draw on the display’s hardness surface using fingers or stylus. A Full HD screen guarantees crisp and vivid image quality, while 350-nit brightness and wide viewing angles provide better visual performance in well-lit rooms. With built-in dual core processor and 8GB internal storage, as well as integrated versatile connectivity including HDMI, VGA, YPbPr, RS232, RJ45 and USB ports, this display provides powerful computing for annotation and multimedia playback without the need for a PCThis Energy Star certified display delivers optional slot-in PC (NMP710) capability, offering Windows®8 Professional (64 Bit) OS and ViewBoard annotation software for more computing-intensive interactive applications. The CDE7060T is VESA mountable (wall mount kit WMK-047 included for Europe region) or choose the optional trolley cart for flexible installation for classrooms and corporate meeting rooms.
ViewSonic 70" LED display
LED-backlit LCD flat panel display
Diagonal Size
70"
Commercial Use
Resolution
1920 x 1080
Display Format
1080p (FullHD)
Video Interface
HDMI
LAN
PC Interface
VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight
Speaker System
2 speakers
USB Port
Remote Control
Remote control
AC 100/240 V ( 50/60 Hz )
Diagonal Size
70"
Commercial Use
Video Interface
HDMI
PC Interface
VGA (HD-15)
HDCP Compatible
Display
Resolution
1920 x 1080
Display Format
1080p (FullHD)
LED backlight
Media Player
USB Port
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Network & Internet Multimedia
LAN
Power supply
Nominal Voltage
