Product
ViewSonic CDE6560T 65" 1920x1080 8ms VGA DVI HDMI DP LED LFD
Quicklinx: BHCLWS00 Mfr#: CDE6560T
  • 1080p (Full HD)
ViewSonic CDE6560T 65" Full HD interactive LED display solution is perfect for business and education. This 10-point touch-enabled display, paired with pre-installed annotation software, allows multiple users to simultaneously write or draw on the display's hardness surface using fingers or stylus. A Full HD screen guarantees crisp and vivid image quality, while 360-nit brightness and wide viewing angles provide better visual performance in well-lit rooms. With built-in dual core processor and 8GB internal storage, as well as integrated versatile connectivity including HDMI, VGA, YPbPr, RS232, RJ45 and USB ports, this display provides powerful computing for annotation and multimedia playback without the need for a PC. The CDE6560T is VESA mountable (wall mount kit WMK-047 included for Europe region) or choose the optional trolley cart for flexible installation for classrooms and corporate meeting rooms.
  • 10 point touch interactive capabilities for collaboration with multiple users
    With 10-point simultaneous touch technology, the CDE6560T encourages group interaction. Multiple users can simultaneously write or draw on this larger-sized display's 7H hardness surface using styluses or their fingers - or both at the same time! And its superior touch report rate provides a smoother user touch experience for both educational and corporate applications.
  • Easy for presentation without the needs of PCs
    Equipped with a powerful dual-core processor, the CDE6560T provides smooth and fast computing for todays demanding applications. This large format display is able to playback presentation files and multimedia contents directly from onboard 8GB memory, USB drive, and even surf the Internet via the LAN connection.
  • Superior screen performance enhances presentation quality
    This large format display features a 1920 x 1080 resolution, 360 nits brightness and 4000:1 contrast ratio, delivering sharp and crisp image performance for in-door environment. The display also features wide viewing angles, delivering true and consistent color performance and ensures the audiences at the corners in the boardroom and classroom can see the presentation files clearly.
  • Eye-Care technologies create comfort viewing environment
    The CDE6560T adopts exclusive Flicker-free and Blue Light Filter eye-care technologies. By nearly eliminating screen flickering at all brightness levels by providing a constant LED light source and reduce blue light exposure, the display ensures longer viewing time and increase eye comfort for presentation and multimedia experience - without eye fatigue.
  • RS232 connectivity for easy multi-device management
    RS232 connectivity enables computers and laptops to be connected to the CDE6560T. RS232 connectivity also allows IT personnel to conveniently manage multiple displays, configure devices, and upgrade firmware from a centralized location. This provides organizations the ability to better maintain and control large numbers of displays from a single location.
  • Protective ID design ensures durability
    A rounded-corner design provides a safer learning environment for active students by helping to prevent injuries in the classroom and it features 7H scratch-resistant surface hardness that ensures durability, as well as a consistent, high-quality touch experience. In addition, an anti-glare film improves screen visibility in bright environments.
  • Energy-saving LED backlight
    The CDE6560T utilizes an energy-saving LED backlight that consumes 35% less power than conventional CCFL backlight displays. This provides for a lower overall cost of ownership, along with a higher ROI, making this display a great long-term investment.
ViewSonic CDE6560T 65" Class (64.5" viewable) LED display
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
65"
Diagonal Size
64.5 in
Commercial Use
Yes - interactive communication
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
480p, 720p, 1080p, 480i
Video Interface
Composite, HDMI
HDMI Ports Qty
3 ports
LAN
PC Interface
VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight
TV Tuner
No tuner
Picture Enhancements
Blue Light Filter
Speaker System
2 speakers
USB
4 ports
Remote Control
Standard remote
Voltage
AC 100/240 V (50/60 Hz)
270 Watt
154.5 cm x 9.6 cm x 93.7 cm
69 kg
270 Watt
Diagonal Class
65"
Diagonal Size
64.5 in
Commercial Use
Combined with
Touchscreen
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
Composite, HDMI
HDMI Ports Qty
3 ports
PC Interface
VGA (HD-15)
HDCP Compatible
Blue Light Filter
Protection
Anti-scratch display
154.5 cm
9.6 cm
93.7 cm
69 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
LED backlight
Coating
Anti-glare, 7H Hard
Colour Depth
10-bit colour
Image Contrast Ratio
4000:1
Brightness
360 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Touchpoints Qty
10
Response Time
8 ms
Backlight Life
50,000 hour(s)
Colour Temperature Control
Eye Care, infrared multitouch technology, Flicker free technology
Stands & Mounts
Flat Panel Mount Interface
600 x 400 mm
Video Features
Input Video Formats
Media Player
USB Port
USB Ports Qty
4
PC Configuration
ARM Cortex-A9 Dual-Core / 1.5 GB DDR3 / 8 GB Flash / Mali 400
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Network & Internet Multimedia
LAN
LAN Protocol
Gigabit Ethernet
Connector Type
3 x USB 2.0 , USB 3.0 , USB , 3 x HDMI input , 3 x VGA input , 3 x audio line-in , Composite video input , Digital audio output (optical) , Network , VGA output , Serial input , Headphones
3 styluses, ViewSonic WMK-047 wall mount kit
VGA cable , USB cable , Audio cable , Serial adapter
EAC, EEI
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Width (Shipping)
171.5 cm
Depth (Shipping)
28 cm
Height (Shipping)
108.5 cm
Weight (Shipping)
80 kg
20 - 80% (non-condensing)
