The ViewSonic CDE5560T 55''(54.6'' viewable) Full HD interactive LED display solution is perfect for business and education. This 10-point touch-enabled display, paired with pre-installed annotation software, allows multiple users to simultaneously write or draw on the display's hardness surface using fingers or stylus. A Full HD screen guarantees crisp and vivid image quality, while 350-nit brightness and wide viewing angles provide better visual performance in well-lit rooms. With built-in dual core processor and 8GB internal storage, as well as integrated versatile connectivity including HDMI, VGA, YPbPr, RS232, RJ45 and USB ports, this display provides powerful computing for annotation and multimedia playback without the need for a PC.
10 point touch interactive capabilities for collaboration with multiple users
With 10-point simultaneous touch technology, the CDE5560T encourages group interaction. Multiple users can simultaneously write or draw on this larger-sized display's 7H hardness surface using styluses or their fingers - or both at the same time! And its superior touch report rate provides a smoother user touch experience for both educational and corporate applications. -
Easy for presentation without the needs of PCs click to collapse contents
Equipped with a powerful dual-core processor, the CDE5560T provides smooth, lightning-fast computing no matter what applications are running. This large format display is able to playback presentation files and multimedia contents directly from onboard 8GB memory, USB drive, and even surf the Internet via the LAN connection. -
Superior screen performance enhances presentation quality click to collapse contents
This large format display features a 1920 x 1080 resolution, 350 nits brightness and 1400:1 contrast ratio, delivering sharp and crisp image performance for in-door environment. The display also features wide viewing angles, delivering true and consistent color performance and ensures the audiences at the corners in the boardroom and classroom can see the presentation files clearly. -
Eye-Care technologies create comfort viewing environment click to collapse contents
The CDE5560T adopts exclusive Flicker-free and Blue Light Filter eye-care technologies. By nearly eliminating screen flickering at all brightness levels by providing a constant LED light source and reduce blue light exposure, the display ensures longer viewing time and increase eye comfort for presentation and multimedia experience - without eye fatigue. -
Flexible Installation through Versatile Connectivity click to collapse contents
The CDE5560T integrates 3 x HDMI, 3 x VGA and component inputs for more flexible installations. In addition, its PIP (picture in picture) function lets a presenter show more by selecting an additional high-definition input signal to make presentations more interesting. -
RS232 Connectivity for Easy Multi-device Management click to collapse contents
RS232 connectivity enables computers and laptops to be connected to the CDE5560T. RS232 connectivity also allows IT personnel to conveniently manage multiple displays, configure devices, and upgrade firmware from a centralized location. This provides organizations the ability to better maintain and control large numbers of displays from a single location. -
Protective ID design ensures durability click to collapse contents
A rounded-corner design provides a safer learning environment for active students by helping to prevent injuries in the classroom and it features 7H scratch-resistant surface hardness that ensures durability, as well as a consistent, high-quality touch experience. In addition, an anti-glare film improves screen visibility in bright environments. -
Energy-Saving LED backlight click to collapse contents
The CDE5560T utilizes an energy-saving LED backlight that consumes 35% less power than conventional CCFL backlight displays. This provides for a lower overall cost of ownership, along with a higher ROI, making this display a great long-term investment.
- ViewSonic CDE5560T 55" Class (54.6" viewable) LED-backlit LCD display - Full HD - for interactive communication
- Product Type
- LED-backlit LCD flat panel display with touchscreen
- Diagonal Class
- 55"
- Diagonal Size
- 54.6"
- Commercial Use
- Yes - interactive
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Video Interface
- Composite, HDMI
- HDMI Ports Qty
- 3 ports
- Connectivity
- LAN
- PC Interface
- VGA (HD-15)
- HDCP Compatible
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Picture Enhancements
- Blue Light Filter
- Speaker System
- 2 speakers
- Storage Capacity
- 8 GB Flash
- USB
- 4 ports
- Included Accessories
- Remote control, 3 styluses, ViewSonic WMK-047 wall mount kit
- Voltage
- AC 120/230 V (50/60 Hz)
- 190 Watt
- Power Consumption Stand by
- 0.5 Watt
- 131.5 cm x 9.3 cm x 80.5 cm
- 54 kg
- Product Type
- 190 Watt
- Diagonal Class
- 55"
- Diagonal Size
- 54.6"
- Commercial Use
- Yes - interactive
- Combined With
- Touchscreen
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- Composite, HDMI
- HDMI Ports Qty
- 3 ports
- PC Interface
- VGA (HD-15)
- HDCP Compatible
- Blue Light Filter
- Protection
- Anti-scratch display
- 131.5 cm
- 9.3 cm
- 80.5 cm
- 54 kg
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight
- Coating
- Anti-glare, 7H Hard
- Colour Depth
- 16.7 million colours
- Image Contrast Ratio
- 1400:1
- Brightness
- 350 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Touchpoints Qty
- 10
- Response Time
- 6 ms
- Backlight Life
- 50,000 hour(s)
- Infrared multitouch technology, Flicker free technology
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 400 mm
Media Player
- USB Port
- USB Ports Qty
- 4
- Configuration
- ARM Cortex-A9 Dual-Core - 1.5 GB DDR3 - 8 GB Flash - Mali 400
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
Network & Internet Multimedia
- Connectivity
- LAN
- LAN Protocol
- Gigabit Ethernet
- Connector Type
- 3 x USB 2.0 , USB 3.0 , USB , 3 x HDMI input , 3 x VGA input , 3 x audio line-in , Composite video/audio input , Digital audio output (coaxial) , LAN , Headphones
- 3 styluses, ViewSonic WMK-047 wall mount kit
- Cables Included
- VGA cable , USB cable , Audio cable , Serial adapter
- EAC
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- On / Off Switch
- Width (Shipping)
- 148 cm
- Depth (Shipping)
- 28 cm
- Height (Shipping)
- 95.5 cm
- Weight (Shipping)
- 65 kg
- 0 °C
- 40 °C
- 20 - 80% (non-condensing)
