Verbatim Store 'n' Go Pin Stripe USB Drive - USB flash drive - 16 GB - USB 2.0 - black
Quicklinx: 71X8WS00 Mfr#: 49063
With USB ports in almost every computer and popping up in cars, DVD and multimedia players, TVs, photo frames and more, USB drives are now being considered an essential accessory.
The Store 'n' Go PinStripe USB drive from Verbatim has a push and pull sliding feature which protects the USB connection when it is not in use without the need for a separate cap which is easily lost.
This USB flash drive comes in paper blister package.
Verbatim PinStripe USB Drive - USB flash drive - 16 GB
USB flash drive
Interface Type
USB 2.0
Storage Capacity
16 GB
Enclosure Colour
Apple MacOS X 10.1 or later, Linux Kernel 2.6 or later, Microsoft Windows 7 or later
Microsoft Certification
Certified for Windows Vista
USB flash drive
Storage Capacity
16 GB
Enclosure Colour
Read Rate
Up to 8 MB/s
Write Rate
Up to 2.5 MB/s
Interface Type
USB 2.0
Retractable connector
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
Limited warranty - lifetime
54 mm
21 mm
9.22 mm
8.6 g
