Product
Verbatim LED Lighting Capsule G4 1W (Warm White)
Quicklinx: 9R56WS00 Mfr#: 52143
Verbatim 52143. Light colour: Warm white. Energy efficiency class: A++, Bulb voltage: 12V, Input frequency: 50/60 Hz. Length: 4.1 cm, Width: 1.38 cm, Height: 1.38 cm. Package width: 13.5 cm, Package depth: 1.5 cm, Package height: 9 cm - G4 Socket - 12V AC/DC Voltage - 25,000 hours Lifetime - 90% Energy Saving - Lumen: 80 - Equivalent to 10W incandescent bulb
Verbatim - LED light bulb
Light Bulb Type
LED light bulb
Shape
Capsule
Socket Type
G4
Wattage
1 W
Wattage Equivalent
10 W
Light Bulb Energy Efficiency Class
A++
Colour of Illumination
Warm white light
Colour Temperature
2700 K
Luminous Power
80 lumens
Beam Angle
100 degree(s)
Dimmable
No
AC/DC 12 V
Frequency Required
50/60 Hz
Light Bulb
LED light bulb
Shape
Capsule
Socket Type
G4
Wattage
1 W
Wattage Equivalent
10 W
A++
Warm white light
Colour Temperature
2700 K
Colour Rendering Index
3000
Luminous Power
80 lumens
Luminous Efficacy
80 lm/W
Maximum Beam Candela Power
27 cd
Beam Angle
100 degree(s)
Dimmable
No
Lifetime
25000 hours
Switch Cycles
40000
Power Requirements
AC/DC 12 V
Frequency Required
50/60 Hz
Diameter
14 mm
Length
41 mm
8 g
