Verbatim LED Classic A offers a direct replacement for a conventional incandescent lamp. This dimmable and elegantly designed lamp has a built in temperature control system that protects the lamp electronics from overheating.
- E27 Socket
- 220 - 240 V Voltage
- 30,000 hours lifetime
- 85% Energy Saving
- Lumen: 860
- Equivalent to 63W incandescent bulb
Application - Basic lighting for a comfortable atmosphere at home, in hotel rooms, restaurants and other similar applications.
- Verbatim Classic A - LED light bulb - frosted finish - E27 - 9.5 W - warm white light - 3000 K
- Light Source Type
- LED light bulb
- Bulb Finish
- Frosted
- Socket Type
- E27
- Wattage
- 9.5 W
- Wattage Equivalent
- 63 W
- Energy Efficiency Class
- A+
- Colour of Illumination
- Warm white light
- Colour Temperature
- 3000 K
- Luminous Power
- 860 lumens
- Beam Angle
- 130 degree(s)
- Dimmable
- No
- Voltage Required
- AC 220 - 240 V
- Frequency Required
- 50 - 60 Hz
Light Source
- LED light bulb
- Bulb Finish
- Frosted
- Socket Type
- E27
- Wattage
- 9.5 W
- 63 W
- A+
- Power Factor
- 0.9
- Warm white light
- 3000 K
- Colour Rendering Index
- 80
- Luminous Power
- 860 lumens
- Maximum Beam Candela Power
- 190 cd
- Beam Angle
- 130 degree(s)
- Dimmable
- No
- Lifetime
- 30000 hours
- Switch Cycles
- 20000
Power Requirements
- Voltage Required
- AC 220 - 240 V
- 50 - 60 Hz
- Package
- Blister
- Diameter
- 60 mm
- Length
- 112 mm
- 199 g
