LightScribe technology is an integrated system that combines the DVD drive of your LightScribe-enabled computer with specially coated discs. These discs can then have laser-etched labels burned directly onto the disc surface by the same laser that burns the content of the discs. This is all possible with enhanced disc-burning software.
- Verbatim LightScribe - DVD+R x 10 - 4.7 GB - storage media
- Storage media - DVD+R
- Media Included Qty
- 10
- Native Capacity
- 4.7 GB
- Recording Time
- 120min
- Write Speed
- 16x (max)
- Disc Labeling Technology
- LightScribe Media Version 1.2 Coating Technology
- AZO recording layer
- Package Type
- Spindle
- DVD+R
- 10
- Max. Write Speed
- 16x
Media
- Native Capacity
- 4.7 GB
- Recording Time
- 120min
- Package Type
- Spindle
Customer reviews
Write a review for the Verbatim DVD+R 4.7GB V1.2 Lightscribe 10 Pack here!
No problems
Reviewed by Paul. Review Posted 28/10/2008
Great quality. Never had any problems.
Overall
Ease of use
Value for money
Takes a long time but is good
Reviewed by Anonymous Review Posted 17/07/2008
Each disc (in high quality mode) takes about 20 mins, and the results are even better if you burn them twice (40 mins). For very simple labels, burn time is around 5 mins*.
The results look really good (whereas labels can peel off, unbalance a disc and possibly damage the data layer). Lightscribe is not colour but it is a good, permanent way to label discs. I'd recommend lightscribe for archiving or special projects.
*I used Nero 7 and an Optiarc drive with these discs
Overall
Ease of use
Value for money
Verbatim Lightscribe DVD+R
Reviewed by Richard. Review Posted 01/03/2007
No problems at all.
Nice pics and good quality burning.
Overall
Ease of use
Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
