CD-R is short for "CD-Recordable". The discs are also known as WORM media which stands for Write Once, Read Multiple. The advantage of CD-R over other types of optical media is that you can use the discs with a standard CD player.
The mechanical specifications of Verbatim media are very precise, and data written to it can be read in a wide range of drives. As a result, Verbatim DataLifePlus discs demonstrate a high level of compatibility between drives running at a wide range of speeds.
- Verbatim DataLifePlus - CD-R x 50 - 700 MB - storage media
- Storage media - CD-R
- Media Included Qty
- 50
- Native Capacity
- 700 MB
- Write Speed
- 52x (max)
- Wide printable surface, Super AZO recording dye
- Package Type
- Spindle
- Limited lifetime warranty
- CD-R
- 50
- Max. Write Speed
- 52x
Media
- Native Capacity
- 700 MB
- Archival Life
- 100 years
- Package Type
- Spindle
