High performance Acrylonitrile Butadiene Styrene (ABS) is a commonly used thermoplastic. It is not considered food safe. Highly durable and more flexible than PLA, it offers good heat resistance and a smooth finish. To avoid warping, a printer with a heated bed is required. The optimum operating temperature is between 230°C and 240°C on most printers.
- Verbatim - blue - ABS filament
- Product Type
- ABS filament
- Filament Diameter
- 1.75 mm
- 1 kg
- Printing Technology
- FDM
- Printing Colour
- Blue
Consumable
- Consumable Type
- ABS filament
- Filament Diameter
- 1.75 mm
- 1 kg
- FDM
- Blue
- Nozzle Temperature
- 240 °C
