With USB ports in almost every computer and popping up in cars, DVD and multimedia players, TV's, photo frames and more, USB drives are now being considered an essential accessory.
The Store 'n' Go PinStripe USB drive from Verbatim has a push and pull sliding feature which protects the USB connection when it is not in use without the need for a separate cap which is easily lost.
This USB flash drive comes in paper blister package.
- Verbatim PinStripe USB Drive - USB flash drive - 4 GB
- Product Type
- USB flash drive
- Interface Type
- USB 2.0
- Storage Capacity
- 4 GB
- Enclosure Colour
- Black
- OS Required
- Apple MacOS 9.0 or later, Microsoft Windows 2000/XP/Vista/7, Linux 2.4.0 or later
- Microsoft Certification
- Certified for Windows Vista
- 2-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 4 GB
- Enclosure Colour
- Black
- Read Rate
- Up to 10 MB/s
- Write Rate
- Up to 4 MB/s
- Interface Type
- USB 2.0
- Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
- OS Required
- Limited warranty - 2 years
- 54 mm
- 21 mm
- 9.2 mm
- 8.6 g
