With USB ports in almost every computer and popping up in cars, DVD and multimedia players, TV's, photo frames and more, USB drives are now being considered an essential accessory.
The Store 'n' Go PinStripe USB drive from Verbatim has a push and pull sliding feature which protects the USB connection when it is not in use without the need for a separate cap which is easily lost.
This USB flash drive comes in paper blister package.
Efficient data transfer
Experience swift data management with the Verbatim PinStripe USB Drive, featuring a read rate of 10 MB/s and a write rate of 4 MB/s. This efficient performance ensures your files are transferred quickly and reliably. -
Broad compatibility
Designed to work seamlessly across various platforms, the Verbatim PinStripe USB Drive offers extensive compatibility with both Mac and PC systems. This flexibility makes it an ideal choice for users who operate across different operating environments. -
Easy connectivity
With its USB 2.0 interface, the Verbatim PinStripe USB Drive ensures easy connectivity. The 4-pin USB Type-A connector allows for straightforward connection to a wide range of devices, facilitating hassle-free data access and storage.
- Verbatim PinStripe USB Drive - USB flash drive - 4 GB
- Product Type
- USB flash drive
- Interface Type
- USB 2.0
- Storage Capacity
- 4 GB
- Enclosure Colour
- Black
- OS Required
- Apple MacOS 9.0 or later, Microsoft Windows 2000/XP/Vista/7, Linux 2.4.0 or later
- Microsoft Certification
- Certified for Windows Vista
- 2-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 4 GB
- Enclosure Colour
- Black
- Read Rate
- Up to 10 MB/s
- Write Rate
- Up to 4 MB/s
- Interface Type
- USB 2.0
- Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
- OS Required
- Limited warranty - 2 years
- 54 mm
- 21 mm
- 9.2 mm
- 8.6 g
